There were several different procedures put forward here none of which match the original factory installation exactly. My take on the assembly is that the time to heat the hub is the determining factor. I put the bearing stack in the freezer for an hour or so prior to installing. When the center of the wheel hub gets to a point where you can watch spit bubble when you wipe a little on the installation side of the casting the axle and bearing stack will slide right in literally with a soft plunk. I use an 850 w heat gun. Before that I used two propane torches one held on either side moving constantly. Quick way to set yourself on fire...heat gun better.Damn, you make it sound so easy. Heat is the key - I know that now. I'm told +210??. Next time I'll take the bare wheel to the local pizza kitchen....That's great information to know you experienced the factory installation first hand. Thanks!
