Blown valve and blown piston...![]()
Been trying to figure this on out myselfC'mon, is this another 9L of oil too much for an oilhead or how far can you go on a bald tire?
The exhaust valve necked. If caught with a funny miss and a compression test, head off and a look see.
Months later and lots of good weigh in, it's a blown mess. What a waste of time to help determine something so simple. This one meets my criteria for my wall of shame.
The moderators on these forums must start reading the posts and determine which ones merit the volunteer effort to help us ride against the ones that post going to the junk-mail.
I wonder how many of us got the spam that followed our efforts to help a fellow rider.
I am having a difficult time keeping my mouth shut. I hope I never become so all knowing and wise that I have to make a comment like this to feel good about myself.
\C'mon, is this another 9L of oil too much for an oilhead or how far can you go on a bald tire?
It is unfortunate that the dropped valve (and spark plug?) contributed to a destroyed piston and likely extensive engine damage. However, as pointed out in an earlier post, one likely can obtain a used engine for much less than the repair parts would cost. [it appears that BeemerBoneYard has several engines available in the $500 range.]
If the OP parts out the remaining good bits of his engine, he may recoup much of the cost. There will be shipping costs and a significant amount of labor involved. It sounds like the OP doesn't mind doing mechanical work. From personal experience I can tell you that doing such work can be rewarding (and frustrating!) and usually is a learning experience. Just remember that education isn't cheap. {And one sometimes doesn't get it exactly right the first time!}
Good Luck with this project. Take lots of pictures. Post 'em as you progress. As much as I like reading the well documented posts currently on-going about various RS restorations, I also like (and vicariously learn) from less expert experiences.
How do you explain the spotless valves in post #79?
That is only seen on a near new engine.
Or if you clean them with a lot of effort...
