Did my valves and bike sounds much better. Put new plugs in (Autolites 3923 - gapped to 0.31). Been trying to get the bike nicely tuned. Replaced some fuel hoses which solved other issues. Now I'm trying to focus on an idling issue. You can see on the video that it idles fine then wants to briefly cut out. Also, when I rev it up and chop it, I get a decent pop from the muffler (which can be seen on the video as well).
Going to be getting a throttle body tuner (Carbtune Pro 4) to make sure that's good, but wondering what may be causing the two issues mentioned above. Tested the battery and it was 12.34 volts. Could that be causing the rough idle. Starts and idles fine when warm.
My thoughts are tuning idle with big brass screws and then complete throttle sync... Is this the next logical step? Anything else I should be checking?
