Scarletswirl
Member
My 95 R100RT is running on one cylinder. I have accomplished the following troubleshooting so far:
1. Checked that fuel is flowing to both carbs. It is.
2. Installed new spark plug wires, new spark plugs. No change.
3. With both spark plug wires connected and spark plugs out, it appears that only one plug is firing, the Left.
4. With both spark plugs installed, shorted Right plug, no change. Shorted Left plug, engine quit. (Confirms step 3)
5. Swapped the leads at the coil. and repeated step 4. Now engine quits when Right plug is shorted.
6. Checked resistance across coil secondaries and got 13 Kohm. Not in spec according to Hayes, but identical to a brand new Dyna Tech coil.
Before I replace the coil, has anyone seen this before, where only ONE side of the coil goes bad? Does the fact that the resistance value across the secondary is not in spec on the new Dana Tech coil mean it's bad (even if it's brand new)?
One last question. It appears that there are wires from every harness on the bike that come together right above the coil. Does anyone know how to disconnect them, or can the coil be replace without disconnecting all those wires?
Any hint appreciated
Marc
Marc
