Gear shift indicator
beemer01
Active member
My new to me K100RS is exhibiting a strange gear indicator problem. When cold the gear shift indicator works fine - but when it warms up the indicator becomes intermittent and than vanishes completely taking the neutral light along with it.
I plan to do the Curry test and see if the signals coming up to the plug are right, but is there a chance that the connector is bad? That is certainly in the heat from the engine...
Perhaps this is just wishful thinking and I will have to take the trans off to get to the plug.
I Know I'm old school...never had an indicator telling me what gear I was in...just knew where I was:p (BSA 441, Triumphs, and even a first year Honda 750).
I have become an advicate that if it is designed into the machine it should work:thumb
Please let US know what you find.
Thanks----tim
The plug on my 1989 models is under the right side panel, and easy to access. Hopefully it was done the same way in 1985.
The switch itself is on the back of the trans, so only the swingarm has to come off if you want to replace it. Its not a hard job.
had a similar problem on 94 k110LT, the 4 wire connector on right side below tank wasnt real tight and lost some contact intermitantly, which is a real joy. boils down to going back to basics and checking out things that at first may look ok but hiding their secrets.
When replacing use the gasket offered and a little high temp silicone to prevent future moisture from getting in there.
