BouncinBob
Encumbered by employment
I've tried to find the nitrate free coolant to avoid $24 gallon for the BMW version. Anybody now a chain of stores that may carry one?
Ready to use cooling liquid
Anti-corrosion and anti freeze,
Protection -35??C/-31??F
AOT Technology
Nitrite free / Amine free / Phosphate free / Borate free / Silicate free
MOTUL MOTOCOOL FACTORY LINE is a racing cooling liquid, ready to use, based on monoethyleneglycol, using organic anti-corrosion additives to provide an outstanding protection to aluminium/magnesium alloys used by bike manufacturers on new engines design.
PERFORMANCES
Cooling system optimal protection from freezing and metallic parts from corrosion.
Specific anti-corrosion agents provides the best protection efficiency on aluminium/magnesium alloys ÔÇô according to a dynamic corrosion test performed on a bike radiator, MOTOCOOL FACTORY LINE divides by 3 the corrosion rate compared to a common organic coolant.
Provides an excellent thermal exchange and then engine cooling efficiency and prevents from boiling.
This organic technology provides anti-corrosion properties that remain while high temperature and ageing. Low corrosion inhibitors consumption allows extended drain intervals. Water pump protection, avoid cavitation.
Seals, durits and plastic parts friendly.
Contains a bitterness agent to prevent from drinking : coolants and antifreezes have a sweet taste but are harmful.
RECOMMENDATIONS
Ready to use, do not add any water
Drain intervals : Refer to the manufacturers' recommendation.
Do not mix with non organic products.
This product should not be used to protect drinking water systems against freezing.
Why won't any anti-freeze/coolant that's designed for aluminum engines work?
...according to a dynamic corrosion test performed on a bike radiator, MOTOCOOL FACTORY LINE divides by 3 the corrosion rate compared to a common organic coolant.
Just in case you missed it:
R bike owners are laughing at us K bike owners worrying about coolant.
Let em laugh, how many times have they had to replace push rod seals???![]()
Xerex G05
+1
