As most of the K52 R1200xx owners know, BMW has made it's cam timing tools unavailable to the public. These include:
I also ordered these parts directly from Europe, waited months "on backorder", until I directly inquired and the vendor informed me that though they were still in their catalog, BMW wasn't shipping these parts.
A few members on this forum have done a great service, developing their own kits, now available for sale. While I do appreciate their enterprise, and I'd (reluctantly) cough up the cash for an OEM tool, their kit is a bit too rich for my blood for an after market made tool. (If for no other reason than I could resell an OEM tool later, but a machined duplicate, maybe not so much.)
Since my first effort, others have put similar tools out on the market (many, it seems, coming from the more mature BMW European market), others from Europe via China (ughh!).
I was able to find both duplicate alignment pin and jig tools on the market for a reasonable price, which also have good reviews from owners. The timing chain tensioner and spacing sleeve? Not so much, both in terms of availability and proven reliability. This is what I've found, thus far.
Nippy Normans - part MKS-TOA44292
Motorworks UK, same part, same price
I included Motorworks, which does not appear to have options for shipping to the USA (though such maybe available), because they have a little better tool operating description than Nippy Normans, plus a video. To wit:
After I sent in a question, Nippy Norman's returned the same video.
I also found a similar, alternative tool on Amazon.
Road Passion 11318542060 Cam Timing Chain Tensioner Compatible with BMW K50 (R 1200 GS)(10/2011-07/2018)/K51 (R 1200 GS Adventure)(09/2012-08/2018)/K52 (R 1200 RT)(01/2013-07/2018)/K53 (R 1200 R)
Neither of these tool alternatives includes the spacer sleeve, though the video and description indicates that there will be about a 10mm gap (right cylinder only?!), which looks to be equivalent to the OEM sleeve length. The OEM tool looks like this (note, the alignment pin tool and jig are top and bottom; the cam chain adjuster tools in between, along with the OEM sleeve.
This is the Nippy Norman/Motorworks alternative cam chain adjuster tool.
This is the version available on Amazon.
What I'm a bit uncomfortable on ALL of these non-OEM tools is the torque specification for the tools. I know the tool from our friends on this forum uses a spring to maintain the appropriate tension. The two other alternatives, pictures above (and the video example of the use of the tools), simply indicates "hand tight". BMW's OEM tool uses a clicker via the cap with pins pictures (and, I'm sure, an internal spring inside), to accurately calculate the tension required against the cam chain.
Bottom line and my question(s):
Has anyone else used the two alternative tools pictured above, only tensioned by hand, in timing their Wethead Beemers?
Do you know if any other/better alternative tools?
How torque-critical is the tension required against the timing chain? I realize that the extremes are breaking the chain, or leaving it slack, throwing off the cam chain timing adjustment, which I expect would be detected when the adjustment is checked with the jig.
My guess is that the hand tightened torque adjustment is safe, as long as the jig tests and confirms the adjustment.
Thanks in advance, for your feedback.
This timing chain tensioner assembly tool is used to place the correct tension on the timing chain before performing the cam alignment procedure (using the valve locking tool TOA27790)
Important to note - when using this tool, hand tighten it on the chain slider. DO NOT use a wrench/spanner on it! This tool does not have a spring unlike the OEM tool. This spring is designed to limit the amount of torque on the chain guide so that you do not tighten in until it cracks. This is why with this tool it is important to hand tighten it, and you will be able to feel when the guide is pushing the chain which is when you then stop tightening it and continue with the engine work.
For the right hand side, on R1200 models leave a 10 mm gap between the brass part and the engine, since it does not protrude all the way in like on the left hand side.
