This thread contains the videos that Chris Harris has posted on youtube. A few other authors are noted as indicated. Note that this is Chris Harris' product and is not necessarily sanctioned by BMW or the MOA. So, take that into consideration. In addition, you'll need to put your "bleep" word filter on, because the guy is pretty free with his language.
Before the listing of the youtube videos, here's another link to K75 tech videos that was posted by drneo66 in another thread. Thanks for that!
K75 Tech videos - http://forums.bmwmoa.org/showthread.php?72407-All-the-K75-Tech-Videos-that-Fit
Now the Chris Harris videos. They arranged mostly by model type...in most cases the subject discussed will cover a range of bikes/years within that model.
Airhead
1973 R75/5 carb assembly -
1973 R75/5 carb disassembly -
1989 R100GS transmission rear bearing failure -
1992 R100GS carb disassembly -
1972 R75/5 rear main seal and oil pump o-ring - https://www.youtube.com/watch?v=R0GwMcAHWw8
1974 R75/6 front brake caliper adjustment - https://www.youtube.com/watch?v=50tiDB26TIo
1975 R90/6 pushrod tube replacement (by Illinois BMW Riders) - https://www.youtube.com/watch?v=ib_VblhJ6Q0
1977 R100RS restoration (Brook Reams) - https://www.youtube.com/channel/UCQzNs09m3GMIJmFTBFEeM6w
1982 R100 transmission spline lube part 1 - https://www.youtube.com/watch?v=uVKPGcf0xag
1982 R100 transmission spline lube part 2 - https://www.youtube.com/watch?v=p8dJzD42eYI
1982 R100 transmission spline lube part 3 - https://www.youtube.com/watch?v=p0Kw38blwfg
1982 R100 transmission spline lube part 4 - https://www.youtube.com/watch?v=qXXnNQf2F_k
1982 R100RT valve adjustment - https://www.youtube.com/watch?v=VExx_2kIc9c
1982 R100RS transmission overhaul part 1 (by Moto Phoenix) - https://www.youtube.com/watch?v=qqaXNmJ3Igg
1982 R100RS transmission overhaul part 2 (by Moto Phoenix) - https://www.youtube.com/watch?v=cx_F8416uDk
1982 R100RS transmission overhaul part 3 (by Moto Phoenix) - https://www.youtube.com/watch?v=boMi-ouHcqI
1982 R100RS transmission overhaul part 4 (by Moto Phoenix) - https://www.youtube.com/watch?v=9JJy8T2AWUc
1982 R100RS transmission overhaul part 5 (by Moto Phoenix) - https://www.youtube.com/watch?v=7UXcXqoS6Kc
1982 R100RS transmission overhaul part 6 (by Moto Phoenix) - https://www.youtube.com/watch?v=MZTfH7RPeU8
1982 R100RS transmission overhaul part 7 (by Moto Phoenix) - https://www.youtube.com/watch?v=-lf-91SDP1s
1984 R100RT rewire using Motogadget m-Unit product - https://www.youtube.com/playlist?list=PLKkTzyzikTTLvO_qxCeHpByPjja4nM_TW
Airhead /5 valve adjustment - https://www.youtube.com/watch?app=desktop&v=mrHK0ywdyDU
Airhead /5 clutch cable adjustment - https://www.youtube.com/watch?v=l0Nrjoo6c0s
Airhead /6 clutch cable adjustment - https://www.youtube.com/watch?v=1oj8NMid_LU
Airhead Bing carb idle / mixture screw adjustment - https://www.youtube.com/watch?v=a_HyX1qLPbQ
Airhead Bing carb overhaul (by Illinois BMW Riders) - https://www.youtube.com/watch?v=wAReWIJP1eA
Airhead Bing carb needle adjustment (by SteveD) - https://www.youtube.com/watch?v=vFnTVxm0FVw&feature=youtu.be
Airhead Bing carb balance (by Matt Parkhouse) - https://www.youtube.com/watch?v=5bmJ0iYBYgQ
Airhead choke cable replacement - https://www.youtube.com/watch?v=l8rGcg_0UBo
Airhead diode board test/repair (by Jerry Patterson) - https://www.youtube.com/watch?v=WJHcuuv-OtA
Airhead exhaust nut removal - https://www.youtube.com/watch?v=ZRXKC9Yxfug
Airhead hard starting; plugged choke jet in float bowl - https://www.youtube.com/watch?v=Wpd27HTGCv8
Airhead leakdown test - https://www.youtube.com/watch?v=HWl91is_fSQ
Airhead R60/5 timing and carb synchronization - https://www.youtube.com/watch?v=HShbaC9ORSo
Airhead R90/6 reseal final drive (by Boxer2Valve) - https://www.youtube.com/watch?v=9rw6IQcBnXQ
Airhead R75/6 - R90/6 Enduralast ignition installation (by craydds) - http://craydds.blogspot.com/2011/08/enduralast-wiring-for-75-r90s.html
Airhead starter motor bench test (by EuroMotoElectrics) - https://youtu.be/cfMjfLE4I_E
Airhead steering stem bearing replacement part 1 - https://www.youtube.com/watch?v=8JUnZ5oTQys
Airhead steering stem bearing replacement part 2 - https://www.youtube.com/watch?v=RZR6TQIm3mY
Airhead stripped cylinder stud - https://www.youtube.com/watch?v=zSaQzFpzxpA
Airhead transmission lower water drain hole cleaning - https://www.youtube.com/watch?v=DmLAQsG-TZY
Airhead transmission (general work) (by Anton Largiader) - https://www.youtube.com/watch?v=lITnRZj54eE
Airhead tubeless front tire balance - https://www.youtube.com/watch?v=FK2ZuQmYumU
Airhead tubeless rear tire balance - https://www.youtube.com/watch?v=PAMyxwvRIak
Airhead CV carb overhaul (Pt 1) - https://www.youtube.com/watch?v=F4_C5B-SjFo&t=21s
Airhead CV carb overhaul (Pt 2) - https://www.youtube.com/watch?v=zxyC7wtS40w
Airhead CV carb operation - https://www.youtube.com/watch?v=hDsJH1Y9W_U&list=PLOMI8_0YotYJA3lkNFTxkF7nE1Ygp3nqS
Airhead rectifier check (MotoPhoenix) - https://www.youtube.com/watch?v=MrA3pbookBo
Airhead starter motor Part 1 (MotoPhoenix) - https://www.youtube.com/watch?v=64d7ZlERd9E
Airhead starter motor Part 2 (MotoPhoenix) - https://www.youtube.com/watch?v=mV9wjPDc4ks
Airhead starter motor Part 3 (MotoPhoenix) - https://www.youtube.com/watch?v=WocPZnnAiYo
Airhead starter motor Part 4 (MotoPhoenix) - https://www.youtube.com/watch?v=D1aYvsZItI0
Airhead starter motor Part 5 (MotoPhoenix) - https://www.youtube.com/watch?v=DtwxRc4Ra04
R80/7 Airhead charging troubleshooting (MotoPhoenix) - https://youtu.be/oxQwx5EC5X4
R90/6 From the Barn to the Open Road - Tutorial (Boxer2Valve) - http://www.boxer2valve.com/bmw/R90slash6Tutorials.html
R100 pushrod tube seal replacement part 1 - https://www.youtube.com/watch?v=A47LiKSYD9o
R100 pushrod tube seal replacement part 2 - https://www.youtube.com/watch?v=yEFTNrxsWI8
R100 pushrod tube seal replacement part 3 - https://www.youtube.com/watch?v=Y9R_i-w71Rg
R100RT/RS oil cooler elimination - https://www.youtube.com/watch?v=LMdtV8w5-ig
R100GSPD final drive pinion oil seal part 1 (by Moto Phoenix) - https://www.youtube.com/watch?v=b4DqV7aocYg
R100GSPD final drive pinion oil seal part 1 (by Moto Phoenix) - https://www.youtube.com/watch?v=nWvoRU1Mc4k
R100GSPD fork seals - https://www.youtube.com/watch?v=7vfCe9O2z-0
R65 fork assembly - https://www.youtube.com/watch?v=WNHC00THAbw
R65 fork disassembly - https://www.youtube.com/watch?v=ymse3196ORY
Non-Airhead repair shop problems by Ted Porter - https://www.youtube.com/watch?v=R1rI3pog1DU
Bosch-type horn repair (by fenrir00) - https://www.youtube.com/watch?v=O1ig6BxG0uQ
Karcoma petcock repair (by Secession Cycles) - https://www.youtube.com/watch?v=JU_9f7J4JP8&feature=youtu.be
Boxer2valve youtube channel - https://www.youtube.com/results?search_query=boxer2valve
Oilhead
1993 R1100RS cylinder head removal part 1 - https://www.youtube.com/watch?v=ABQJkYQpuIE
1993 R1100RS cylinder head removal part 2 - https://www.youtube.com/watch?v=-7UKrhTOB6Q
1993 R1100RS cylinder head removal part 3 - https://www.youtube.com/watch?v=zyJBZ8v4dw8
1993 R1100RS cylinder head removal part 4 - https://www.youtube.com/watch?v=k4ywCqHAOiY
1993 R1100RS cylinder head removal part 5 - https://www.youtube.com/watch?v=tJ9hU_sJ3Aw
1993 R1100RS cylinder head removal part 6 - https://www.youtube.com/watch?v=TVSnvpvrPN0
1993 R1100RS cylinder head removal part 7 - https://www.youtube.com/watch?v=gJEk0cWBtMw
1993 R1100RS cylinder head removal part 8 - https://www.youtube.com/watch?v=JuEcgH05ikc
1993 R1100RS cylinder head retorque / angle torque - https://www.youtube.com/watch?v=WzA37V9ik1Q
1993 R1100RS fuel filter replacement - https://www.youtube.com/watch?v=-wr_Hs_IBcY
1993 R1100RS stripped cylinder head stud part 1 - https://www.youtube.com/watch?v=3kaIC06hxhs
1993 R1100RS stripped cylinder head stud part 2 - https://www.youtube.com/watch?v=Gp5t0pfCLHU
1993 R1100RS stripped cylinder head stud part 3 - https://www.youtube.com/watch?v=lxepzvPcwtc
1993 R1100RS stripped cylinder head stud part 4 - https://www.youtube.com/watch?v=kRigG5DjygQ
1993 R1100RS throttle body shaft comparison - https://www.youtube.com/watch?v=TpNbzyLGva8
1993 R1100RS valve adjustment procedure - https://www.youtube.com/watch?v=SR8W9tdH3kM
2002 R1150RT fork seal replacement - https://www.youtube.com/watch?v=uEL4MqHC90Q
2004 R1150GS Adventure throttle cable replacement part 1 - https://www.youtube.com/watch?v=ybHjEbUa2NA
2004 R1150GS Adventure throttle cable replacement part 2 - https://www.youtube.com/watch?v=32IqXlWOhzM
2004 R1150RT transmission input shaft failure part 1 - https://www.youtube.com/watch?v=vvQaZhh662Q
2004 R1150RT transmission input shaft failure part 2 - https://www.youtube.com/watch?v=P8do1oqeTzw
Oilhead Cam chain Guide Rail Replacement - https://www.youtube.com/watch?v=SkPrIEzaAMs
Oilhead oil and filter change - https://www.youtube.com/watch?v=R1uPriXhVJ8
Oilhead starter replacement - https://www.youtube.com/watch?v=P9UcXgethHI
Oilhead testing oil pressure - https://www.youtube.com/watch?v=lb-9tvo5-K0
Oilhead valve cover gasket replacement - https://www.youtube.com/watch?v=s2m5bYZ6P_Q
Oilhead Hall Effect Sensor replacement - https://www.youtube.com/watch?v=0g5WD7C4K_0
R850R fuel pressure regulator change - https://www.youtube.com/watch?v=rIeFMmYrhEE
R1100GS clutch replacement - https://www.youtube.com/watch?v=uexPbNymBNo
R1100R cam chain tensioner replacement - https://www.youtube.com/watch?v=Bu1-PdWoC6s
R1100S transmission seal replacement (by Anton Largiader) - https://www.youtube.com/watch?v=Q9_mympXWnE
R1100RSL no start - https://www.youtube.com/watch?v=Ihq4T4Wy9OA
R1100RT seized fairing panel screws - https://www.youtube.com/watch?v=00b-uZXjDdo
R1100RT spline lube - https://www.youtube.com/watch?v=iTZo_pFeYUA
R1100RT Transmission and Clutch Replacement - https://www.youtube.com/watch?v=6gzR4WHD-94
R1100RT Fairing Removal (by Illinois BMW Riders)- https://www.youtube.com/watch?v=yHAcbBiFlsw
R1100RT/R1150 RT mirror glass and turn signal replacement - https://www.youtube.com/watch?v=24fgqlZff7U
R1100RT/R1150RT alternator belt replacement - https://www.youtube.com/watch?v=M9PLUcX-p4s
R1100S centerstand service - https://www.youtube.com/watch?v=BfwLUKRmAdY
R1150 reinstalling cam chain tensioner - https://www.youtube.com/watch?v=jBgO_Fbn02A
R1150/R1200C/K1200RS handlebar switch removal - https://www.youtube.com/watch?v=L7cmLa5EU9Q
R1150GS brake fulid and hoses - https://www.youtube.com/watch?v=otDOxXEE1Zw
R1150R no start - https://www.youtube.com/watch?v=e__MZB-6laM
R1150RT cam chain tensioner replacement - https://www.youtube.com/watch?v=KOT_eyNp9Y8
R1150RT clutch pack removal - https://www.youtube.com/watch?v=ItGV3ACSEzY
R1150RT clutch replacement - https://www.youtube.com/watch?v=-PdVvxMwz_A
R1150RT fork seal replacement - https://www.youtube.com/watch?v=tAQ4KdEZpxs
R1150RT front wheel removal and installation - https://www.youtube.com/watch?v=jpTQyKQ6VUA
R1150RT rear wheel removal and installation - https://www.youtube.com/watch?v=hBwq76fuZbw
R1150RT starter replacement - https://www.youtube.com/watch?v=Ml43uG8QcGU
R1150RT tire mounting and balancing - https://www.youtube.com/watch?v=guyl4uZEkQE
R1150RT transmission noise - https://www.youtube.com/watch?v=S9nZtosj5bw
R1150RTP eliminating the EVO brake system - https://www.youtube.com/watch?v=7xZMewBazMI [video missing ]
R1200C clutch slave cylinder replacement - https://www.youtube.com/watch?v=mLqsry3QPDw
R1200C/CLC intake rubber inspection - https://www.youtube.com/watch?v=eoj01tDbopo
R1200C/R850/R1100/R1150 angle torque/valve adjustment - https://www.youtube.com/watch?v=Oj8ADjrs2qQ
R1200CLC rear brake disc replacement - https://www.youtube.com/watch?v=FVdy5TOxpCM
K-Bike
K100 spline lube part 1 - https://www.youtube.com/watch?v=HZJdZ1HszkA
K100 spline lube part 2 - https://www.youtube.com/watch?v=YCnQE4vQTcs
K100 spline lube part 3 - https://www.youtube.com/watch?v=LcbvZPJa1W0
K100 spline lube part 4 - https://www.youtube.com/watch?v=RybnCX6PlIE
K100 spline lube part 5 - https://www.youtube.com/watch?v=nCaD08Z3Ft0
K100 spline lube part 6 - https://www.youtube.com/watch?v=3sVtMgmTN5g
K1100LT jammed forks - https://www.youtube.com/watch?v=R92FrOQ77wE
K1100LT oil pan replacement - https://www.youtube.com/watch?v=WW6hAj8pgUU
K75 / K100 valve clearance check - https://www.youtube.com/watch?v=bFkPnLVkxWQ
K75/K100 rear drive splines service - https://www.youtube.com/watch?v=EKfD76cF8bk
K75/K100/K1/K1100 clutch adjustment procedure - https://www.youtube.com/watch?v=gBW4D2jDw2A
K75/K100/K1/K1100 fuel cap rebuild - https://www.youtube.com/watch?v=Mwpt9IumBCc
K75/K100/K1100 steering head bearings part 1 - https://www.youtube.com/watch?v=j4jbR8RHHJo
K75/K100/K1100 steering head bearings part 2 - https://www.youtube.com/watch?v=UJr8oYp9rJ0
K75RT / K1100LT electric windscreen repair - https://www.youtube.com/watch?v=st0Kr48FWYA
K75RT/K100LT/K1100LT mirror glass replacement - https://www.youtube.com/watch?v=EbgqpKE5q-M
K1200GT ('08) Clutch Replacement (by AlsMotorrad) - https://www.youtube.com/watch?v=csa4FVyvWD8
K75 breather hose replacement (by Lordofthegadflies) - https://www.youtube.com/watch?v=-cKBW9QsKlI
K75/K100/K1100 air filter replacement - https://www.youtube.com/watch?time_continue=3&v=QLH7IcFeGKo&feature=emb_logo
K-Bike Videos - https://illinoisbmwriders.com/service/instructional-videos [bad URL ]
K75 videos - link to forum post of many videos - https://forums.bmwmoa.org/showthread.php?72407-All-the-K75-Tech-Videos-that-Fit&highlight=
K75S Engine Spoiler Removal/Installation - https://www.youtube.com/watch?v=ToFwtdmph0o
K75S Drive Shaft Spline Lube - https://www.youtube.com/watch?v=DeLlC9XaASA
Hexhead
Vented Final Drives - https://www.youtube.com/watch?v=zskZoHzU4gM
Installation of Mirror Catch Strap - https://www.youtube.com/watch?v=Jo3Bse1kIgU
Spark Plug Change - https://www.youtube.com/watch?v=bxq6LFH-Ie8&t=40s
Wethead
R1200RT 12K Miles Maintenance Videos (6 parts by Boxflyer) - https://forums.bmwmoa.org/showthread.php?97173-R1200-Wethead-Maintenance-Videos-FREE
R1200RTW 12K Miles Scheduled Maintenance - https://www.youtube.com/watch?v=R0UhPhg5MvI
R1200 Shift Mechanism (by Anton Largiader) - https://www.youtube.com/watch?v=-4LwOnHikgk
R1200RT/GS Wethead valve adjustment (by AlsMotorrad) - https://www.youtube.com/watch?v=iJEjGm8ne1g
R1200GS Rekey Pannier Locks - https://www.youtube.com/watch?v=br_RHmloVyE
R1200RT Oil Change - https://www.youtube.com/watch?v=6ofyEYzqYOs
R1200RT Tupperware Removal - https://www.youtube.com/watch?v=2UHU4ZQ2C_Q
R1200 Fuel Filter Replacement - https://www.youtube.com/watch?v=xdyHT3pGm_A&t=8s
F-Twins
F650GS Brake Bleed (by redonKiLaus) - https://www.youtube.com/watch?v=z9rEj-AAYBA
F800 Air Filter Replacement (by MotoInsight) - https://www.youtube.com/watch?v=7TOG62pMBEc&feature=emb_logo
Adventure Series
2014+ R1200GSAw Bodywork and Tank Removal/Install (by JimVonBaden)- https://www.youtube.com/watch?v=kwW2lqC04ls&feature=youtu.be
R1200GS ABS Repair - https://www.youtube.com/watch?v=zFNkluQ_cbM [video missing ]
R1200RTW Cam Timing Tool - https://www.youtube.com/watch?v=3vyMyntSWZ0 [video missing ]
Oil Sight Glass Replacement (by TheBMWGuy) - https://www.youtube.com/watch?v=Mkh4FHUX6fg&t=30s
R1200GSA (2015) Key Fob Battery Replacement (by KenMoto)- https://www.youtube.com/watch?v=lwUlDVsiWGQ
R18
Seat swap - https://www.youtube.com/watch?v=Gw-EkZzKLno
Transmission oil change - https://www.youtube.com/watch?v=XEvd50NAvLI
Final drive oil change - https://www.youtube.com/watch?v=AnHYtbwRVbQ
Adjusting hand and foot controls - https://www.youtube.com/watch?v=Py-9fhg-XMM
Engine oil and filter service - https://www.youtube.com/watch?v=nVGTX-GG7Vo
Slash 2
R50/R60 magneto and ignition timing check - https://www.youtube.com/watch?v=b-liKTw548c
BMW R60 and R67/2 crankshaft check (by Jan Withagen) - https://www.youtube.com/watch?v=eXJuKb1x-xI
/2 Crankshaft overhaul (not actually a video) (by Salis Parts) - https://www.bmwclassicmotorcycles.com/parts/technical-tips/assembly-a-2-cylinder-crankshaft/
/2 Driveshaft Boot Replace and Exhaust Maintenance (by VintageMoto) - https://www.youtube.com/watch?v=iZkrWqTwD70&feature=youtu.be
R60 flywheel removal (by Jan Withagen) - https://www.youtube.com/watch?v=EDdrmayIIyo
Wheel bearing stack removal (by Illinois BMW Riders) - https://youtu.be/IXj01hUKJBg
Setting up a magneto (by VBMWMO) - https://vintagebmw.org/setting-up-a-slash-2-magneto/
General
BMW 6-speed transmission input shaft replacement - https://www.youtube.com/watch?v=INEhEkE6ejM
Clearing ABS I / II fault - https://www.youtube.com/watch?v=rsrrpbb4kJc
ABS II Rebuild and Installation (by Illinois BMW Riders) - https://www.youtube.com/watch?v=R5xWPB_gvFY
Heated grip repair - https://www.youtube.com/watch?v=NBX2qWHfHHc
How to clean rusted parts - https://www.youtube.com/watch?v=aBqHu2IM00o
Paralever rear drive removal and installation - https://www.youtube.com/watch?v=L0_j8SuiFQI
Poor man's soda blaster (by Matthew MCRepair) - https://www.youtube.com/watch?v=KULVhW2tw4I
Discussion of circlip issue on Airhead transmission (by Ted Porter) - https://www.youtube.com/watch?v=9SNFUXsMIQk
BMW system case lock cylinder removal (3 of 3) (by ClassicCycleConnection) - https://www.youtube.com/watch?v=1Ul9BjNjKQk&feature=youtu.be
BMW case lock removal (by SuperMechanic) - https://www.youtube.com/watch?v=vlppCcPogfs
BMW lock cylinder removal (by ClassicCycleConnection) - https://www.youtube.com/watch?v=CyqACUI5qJE
BMW lock cylinder assembly (by BMWMotorradBohling) - https://www.youtube.com/watch?v=mFoke2TS1O8
BMW lock cylinder videos - search youtube for "BMW lock cylinder"
Gas tank relining with POR-15 (by Holden Vintage) - https://www.youtube.com/watch?v=fZoz_PDxksc
Checking wheel bearings - https://youtu.be/zQJhcfdsWTk
Airhead
Oilhead
K-Bike
Hexhead
Wethead
F-Twins
Adventure Series
R18
Slash 2
General
