Post a pic of your Airhead
Welcome to the forum! Nice customized ride! I see a set of Mikunis for some performance. What's that extra rod stick out the rear, somewhat parallel to the rear brake actuation rod?
Yesterday I rode with a few members of the moto gang up and around Mount Greylock, the highest peak in Massachusetts. Lots of dirt roads and back roads. Outdoor dinner at a Mexican place in Stephentown, NY, then another 30 miles south down to Hillsdale to refill on gas.
And eat ice cream.
August 24, 2022 by SPP™ SlowPokePete, on Flickr
About 140 miles on the bike...
SPP
Please make sure you are accurately focused when photographing ice cream next time. :nono
Cool group of bikes :thumb. I would take any one of them. But especially yours and the Interceptor. I had a 1978 R80/7 at one time.
The Rod is Actually Fuel Hose
Back when I travelled distance a lot, about 18,000 total miles/year, I started using fuel hose for my tank overflow/vent line. The idea was if I ever had a leaky hose on the road, I would just cut an appropriate length of the vent hose. Since I just use auto parts fuel hose for the vent line, I replace it every few years due to weather etc.
As for the Mikunis, I switched to those to accommodate the 336 cam I installed in 2001. I like the response from the cam, but the bike was PIA to start with the 40mm Bings. It would finally fire once it backfired like a 20mm cannon. (You should've seen the reaction to that in front of Redbones Bar-B-Que in Somerville, MA a couple of months after 9/11.) Also, the plugs were constantly carbon fouled no matter what I did with the jetting. (Pilot jet didn't occur to me then.) I think the aggressive cam wasn't pulling enough vacuum at low rpm to get a proper response from vacuum actuated CV's.
The Mikunis were initially a 24 mpg nightmare until I realized I had to lean the pilot jets way down. As I cautiously leaned the pilot jets in a step process, I realized the needle jets and main jets had to go rich.
That's the short version of the Mikuni Epic. I have six pages of notes spanning from 2013 to 2017 with different jetting combinations etc.
I sometimes wonder if I should try the Bings again with leaned out pilot jets. Then I come back to my senses and just go for a ride.
Wow, that is some story. Yeah, I would wonder too if the stock Bings might be easier to sort out. Of course, the updated cam means you would still need to tweak things.
