Hearing aids as "connected helmet"
2022 F750gs
I'm wondering if anyone has hand success connecting hearing aid via Bluetooth to the bike.
I go to setting add helmet speakers but they won't connect.
Why would you wear hearing aids on the bike? It will do nothing but accentuate surrounding noises further damaging your hearing. I remove mine and use S Plug.
"OSHA advises that in workplaces with potentially hazardous noise levels, hearing-impaired individuals should not wear their hearing aids without additional hearing protection. In some cases, hearing aids can be worn under protective earmuffs; a hearing conservation professional should evaluate each case individually."
Sent from my SM-S918U1 using Tapatalk
I'm not sure, but look at the links about hearing aids at the bottom of your post. I see 4 or 5 threads about that very thing.
I have not
When I was first told I would need hearing aids, I looked diligently for a pair that could cancel noise as well as boost hearing. The reason, I ride motorcycle and loved the idea of having my smart phone pipe in music and such to listen to.
Sadly there is not such thing and I found as already posted, the aids amplify the noise to a bad level. Now that I have hearing in only one ear, I protect the heck out of it by NOT wearing the aids while riding and using plugs to protect what hearing I still have.
By the way, I ride behind a fairing and still the noise is high. Don't loose what you have, you will not like the results. St.
+1 I'm 100% in on ear plugs. I spent enough time listening to punk rock in clubs and in press rooms with operating offset presses to know that I've damaged my hearing to some degree.
Hearing aids are probably in my future, but having played with ear buds in my helmet 20 years ago, it seems like unless they attenuate road noise to the degree ear plugs do, they're likely just blasting over the ambient helmet noise.
I have a Sena in my Multitech and it's pretty terrific. I like music while I ride, but it's also nice when the GPS is telling me when my exit is coming up.
