subagon
Hopelessly lost
I'm in the middle of changing my tires by hand. No fancy tire changer, I what to know that I can do this on the side of the road.
I should add that I have no instructions for this, but I'm mechanically inclined, so no fear...
Bike info: 1975 R90/6, New tires = Avon Road Riders.
I statred with the front tire and got the old tire off. That was a b*tch, but I got it off
I put on fresh rim tape, plenty of tire lube, and got the first bead of the new tire on easy
. Now I slide the tube into the tire and around the rim. Next put the valve stem thru the hole in the rim. #$%&!
There's no room to fit my hand(s) inside the tire and monkey with the valve stem. Plus I have to push down on the first bead so it goes past the valve stem hole at the same time. I either need three hands or I'm doing something wrong or in the wrong order.
Can someone please enlighten me as to how to get the valve stem thru the hole?
UPDATE:
10 minutes later... I couldn't go to bed knowing that tube had gotten the better of me. Tried one more time and with much cursing and dumb luck, the stem went in.
BUT, I still think there's a better/easier way
UPDATE:
