Tire changing help
subagon
Hopelessly lost
I'm in the middle of changing my tires by hand. No fancy tire changer, I what to know that I can do this on the side of the road.
I should add that I have no instructions for this, but I'm mechanically inclined, so no fear...
Bike info: 1975 R90/6, New tires = Avon Road Riders.
I statred with the front tire and got the old tire off. That was a b*tch, but I got it off :bluduh.
I put on fresh rim tape, plenty of tire lube, and got the first bead of the new tire on easy :dance. Now I slide the tube into the tire and around the rim. Next put the valve stem thru the hole in the rim. #$%&! :banghead There's no room to fit my hand(s) inside the tire and monkey with the valve stem. Plus I have to push down on the first bead so it goes past the valve stem hole at the same time. I either need three hands or I'm doing something wrong or in the wrong order.
Can someone please enlighten me as to how to get the valve stem thru the hole?
UPDATE:
10 minutes later... I couldn't go to bed knowing that tube had gotten the better of me. Tried one more time and with much cursing and dumb luck, the stem went in. :clap
BUT, I still think there's a better/easier way :scratch
No FEAR!
I'm in the middle of changing my tires by hand. No fancy tire changer, I want to know that I can do this on the side of the road.
UPDATE:
Actually, it sounds as if you've got the drill. Yes, it can be a Royal PITA!
I've never had anybody else change a tire for me.
I've been doing this for thirty years (not every day, of course) and all I use are the two small tire irons in the BMW toolkit (and some detergent and water.)
The most I can say is this: take advantage of the drop-center part of the rim, take your time, be patient and one more thing:
The more you do it the easier it gets.
There may be better ways (fancy tools) but not on the side of the road.
Nice goin', dude! :bow
I find it easier to put the stem in the hole first then stuff the tube into the tire around the rim.
Yes, put the stem in first, put the nut on the stem to make sure it stays in place, put the rest of the tube in and spread it out, hit it with some air, let the air out, and then put the other bead in place................Super hassle but no reason that with patience it can't be done............God Bless.......Dennis
Rim Protectors Too
Are you using rim protectors? If not, pick up a few of these also. Not only will they protect your rims from being marred by the tire irons, they may also prevent a small sliver of rim metal from getting lodged between the tube and the tire. If that happens, you will be redoing the tire change to repair the tube. Personnel experience...:doh
http://w6rec.com/duane/bmw/tire/index.htm
Here's a bunch of data for you.
I've always changed my own tires and have gotten fairly good at it over the years. There are still times it's a bitch, and I'm still learning new tricks - and I've been doing this since 1966.
In the last few years I discovered tire lube. I'd always used a few drops of dish soap in a cupful of water, but the lube is much much better. And at about $15 for a gallon tub, it's damn cheap. Get it now and don't wait as long as I did.
There are a lot of tricks to changing tires, for something so simple that doesn't seem possible. But it is. My brother didn't know the tricks and resorted to cutting a tire off to give you the extreme. :)
Here are a few tips: make sure the tire is warm - some can be really stiff, especially old ones. Leaving it on the roof in the sunshine will soften it up in an hour or two.
Ensure the opposite end of the tire you're working is down in the well.
Whenever replacing a tire, service the bearings.
Clean off the black grunge from the bead area of the rim - it's sticky and may prevent the tire from seating properly. Cleaning it off will also make it easier to remove the tire next time.
Cut a shampoo bottle or oil bottle into strips and place between the tire iron and rim as a rim protector.
I've had major problems with the stem as well. There's a trick for that, but I've forgotten at the moment. It may be to start the tire at the stem hole with the tube already installed in the tire, but not all the way around. I think I'll make a tool for the next time I do it - something that threads into the center (where the core goes) with a cord or cable attached, and then just pull the stem through.
Replace the patch kit every year. The glue gets old and doesn't work (don't ask how I found that one out).
Knowing how to repair your tires is an excellent idea - it's one of those things that can be a major delay, even though not that expensive as bike breakdowns go.
Well after getting the stem in the hole around midnight I had to finish the job. Sometime around 1:30 AM :snore I had the new tire on the rim and holding air. Looking at the new tire on the rim really gave me a felling of pride.
This afternoon I'll balance it, change the rear tire, and go out and ride off the first hundred miles.
Thanks for all the pointers!
putting valve stem through that little hole
If you have three hands you can use tire iron's to pry down the tire so your hands can fit between the tire and the rim to install the stem.
Another trick is to use those big vise grips for woodworking that you can clamp the tires sides together to give more room to work. Also use them to clamp the tires to make them fit into the middle of the rims rather than hanging up on the shoulders while you are levering them on with tire iron's. You will have to stretch the tire much less if it is fit into the middle of the rims opposite of the last little bit of bead.
Also learned from my last screw up, I decided to re-use the tube since my last Conti Blitz rear was shot with only 4.1k. So I didn't order a new one. After a tube is inflated and used for a while it will contain air, It will not be nice and flat like a new one. And You guessed it, I pinched a hole in the tube with my last little bite with the tire irons. So I will always have a new tube available even if I decide to reuse the old one.
Front tire balanced and back on. :clap I had to use two 15g spoke weights to balance the tire (I hope that's no too much :uhoh ) The Avon tires don't have any marks on them.
Rear tire in sitting in the sun getting hot and I'm pulling the rear wheel off.
If it were easy, anyone could do it.
Your description sounds like my typical excercise. Get used to it. It gets easier.
here's a tip I learned out of frustration about the valve stem. I put one side of the tire on the rim, I then stuff the tube in the tire getting the valve stem as close to the hole as possible. I then grasp the valve stem at the base with a pair of needle nose plyers. then just push over and down towards the hole. the plyers are stronger than your fingers and this works for me. I use WD-40 on the tire beads. it works well and the excess evaporates or wipes off easy. :thumb :thumb
You can buy a "tube snake" to help with this (google it - they go for about $15 if I remember correctly). Pornographic as it sounds, its basically a tool consisting of a part that screws into the valve connnected to a wire cable with a puller at the end to pull the valve through the rim hole. Haven't used one, but it looks like it would work a treat.
This is one of those jobs that is just a PITA, but it gets done. You try and try, curse and moan (at least I do), and then, out of nowhere, the thing just pops in there as pretty as you please. So I haven't bought a tube snake myself. But each time I do the job, I kinda wonder why....until it pops in.
To each his own.
Nothing is ever easy ...
The saga continutes ...:violin
Okay, time for the rear tire. Read the owners manual, remove nut, slide out axel, "pull the wheel off towards the left swinging arm, then remove to the rear". Sounds easy. Nut, check, axel, check, pull wheel out, no check. First problem is the tire's too fat to slide between the brake shoes nad the "swinging" arm. To add to my greef, I have lugage racks, so no easy exit there. I figure that the fat tire problem is because the old tire is a 120/90 and not 4.00, maybe a littler wider I assume (more on this below). Well I don't really want to take off the lugage rack, it looks like it's really on there good. The read fender looks easy to take off. So off it comes. Oh, guess I have to take off the tail light too. No fight, curse and beg the rear tire out of there.
(...time passes...)
Okay the tire is out.
The tire doesn't look like it was made for this rim. the beads don't look right on the rim, too narrow. Pop off the first bead.
(...time passes...)
Okay first bead off, now the second one.
(...time passes..........................................................)
(Tradionalists are suggested to look away)
Screw this, I've proved that I can do this when I did the front tire. Out comes the jig saw.
(Seconds pass)
Tire off. :D
New tire on, first bead, no problem, stuff the tube in, wider tire, more room, valve slips right in:thumb Put a little air in the tube. Go grab the tire levers for the second bead. Look at rim tape on table. RIM TAPE :banghead Pull out tube AND stem. Put on rim tape. Tube, stem (easy again :D ). Second bead.
(...a little time passes...)
Ask wife for help :bow holding the tire down while I lever. No problem now. Tires done. :clap
Okay, balance it and put it back on the bike.
You don't need to hear the long story of how I couldn't get the wheel back on. Short version....
The new tire is too wide to fit back in between the swing arm and the brake shoes. I litterly took a baseball bat a hit the tire from the rear to drive it "home". I know I have to be doing something wrong.
Can someone explain? :ear
When taking off the wheel I must have knocked the top brake shoe off it's pivot point. It moved just enough so the brake drum wouldn't go on. Once I figured this out the wheel slipped right on. Game over. Fender back on. Put away the tools a nd out for a quick spin around the block.
So will I do it again (using only tire levers)? No. This ate up a big part of my weekend. I know each time I'd get faster, but I've got beter things to do. I'm glad I did it because now I know I can do this on the side of the road (given time). The next time I'm investing in a Harbour Frieght tire changer and a Mojolever.
To those of you out there that only use levers, :bow :bow :bow
Your money, man, but you WILL get better with experience. I wouldn't recommend the expense of that stuff, but if it makes you happy, that's what money's for.
Just think of the mistakes you made this time that you WON'T make next time. It really does get better...,
When removing and installing the rear tire, DO NOT have any air in it. It gives it just enough slack to be able to compress the side of the tire and slip it past the brake...........Good job, glad you got it done...........Dennis
If you mingle with the local airheads you will probably find one of them that has a tire machine. And they will be happy and proud for you to drop by and use it. Then again, in your area you may be the guy with the tire machine.:)
Dennis,
I did let the air out of the tire and it was still a b*tch to take out/put in. I've got to think I was doing something wrong:dunno . I'm looking for a Tech day in Florida and will try to learn more then.
keelerb,
You either have time or money, but never both at the same time:gerg
Right now I have the cash :D
The second tire was faster and having my wife lend a hand helped a lot when levering the final bead.
