58fleetside
Thanks to the group for helping get my "new" '74 R60/6 home.
Since I am new to BMWs I have a few basic questions on repair, parts and updates. Answers to any or all are greatly appreciated.
1. Keys: I have one ignition key only. What is a good source for folding keys? And, do the fork lock and seat lock use the same key as the ignition? If the are the same, what is the trick to getting these other two locks to work? If they use different keys, what is the best way to get keys or locks and keys?
2. Forks: The forks are twisted with the bars forward on the left. The bike tracks straight. What do I need to loosen in order to twist the forks and bars into alignment? I loosened the clamp bolts on the lower yoke but could not get the forks to twist. Do I need to loosen the caps on top of the fork tubes? These take a pin spanner.
3. Also fork related: I have huge fork dive on braking, do Progressive Suspension springs make a large difference? Are there other solutions to the dive? What is the best source for these parts for my model?
4. Tach/speedo: My tach is not working, and has no needle. The speedo works somewhat with the odometer and trip meters broken. The housing is badly scraped. (Yes, this bike was upside down at some point.) Is there a company restoring and rebuilding these gauges? The tach cable is not spinning with engine running. What is the likely cause of this problem?
5. Brake conversion: Is there a way to convert to front dual discs on this drum brake bike? Is this totally unacceptable on a stock '74?
Thanks very much for any words of wisdom.
Stephen
Stephen
