You probably won't fry anything, but the CanBus will probably shut it down if my GS is any indication.
Good points. I have a Gerbing vest 4 A, gloves 2 A, and socks 2 Amps, and will need at least a 7.5 to 10 Amps fuse. Maybe hooking it up SAE connection from the battery, will be the easiest.I believe it's only 5 amps. I cant run my jacket and gloves. I just use the battery tender plug that is connected directly toy battery . It came with a 7.5 amp fuse and I replaced that with a 15 amp fuse as I have for years on all my bikes and it works great. It is actually a better place to plug in , at least for me. You wont have a wire coming out of the dash area to get in the way of things
I got a socket mount from Touratech on my GS that puts a new fused outlet on it. I replaced the dash outlet that wouldn't power my jacket with a dual USB outlet I got on Amazon for like $22. It has the exact BMW harness connector and plugged right in. Perhaps there's a similar battery relocation set up for your bike? Maybe something like this? https://www.motorcycleparts-hornig....ries-Paint-protection/Extra-power-socket.htmlGood points. I have a Gerbing vest 4 A, gloves 2 A, and socks 2 Amps, and will need at least a 7.5 to 10 Amps fuse. Maybe hooking it up SAE connection from the battery, will be the easiest.
Steve
That's a good idea, hooking the outlet directly to the battery, and bypassing the Can-Bus. Maybe another project to do.Yes- I recall being told 5 amps as well. Morton's in Fredericksburg, VA actually disconnects the front port and wires it direct to battery with a 15 amp fuse as part of their pre delivery service. They were like- "it will charge a phone (for now) that's about it".
There has been many threads on these outlet deals. Another problem seems to be initiated in the stock outlets is trying to use the outlet and one of the fancy chargers to maintain the battery on the bike.That's a good idea, hooking the outlet directly to the battery, and bypassing the Can-Bus. Maybe another project to do.
Steve
A semantic distinction without a difference. The CANBUS is the communication network that communicates with the ZFE and without it the ZFE would do next to nothing.The CAN bus doesn't shut anything down; the power distribution module (ZFE on my Hexhead) controls the electrical output to things like the aux power sockets.
THAT should be the end explanation when people start the CANBUS/ZFE debate.A semantic distinction without a difference. The CANBUS is the communication that network that communicates with the ZFE and without it the ZFE would do next to nothing.
I'm trying to find out, how many amps is the power socket, below the right side glove box is rated for? I want to plug in a Gerbing vest and gloves and just want to make sure I don't fry out the wiring, I couldn't find it in the manual.
Thanks for any help.
Steve
Thanks, this sounds like the way to go.There has been many threads on these outlet deals. Another problem seems to be initiated in the stock outlets is trying to use the outlet and one of the fancy chargers to maintain the battery on the bike.
SAE connector direct to the battery, appropriately FUSED.
I also have the Gerbing coaxial connector as well.
Can’t have too many well installed outlets.
Thanks for the info, sounds like on your bike, it's never been an issue, interesting.FWIW: I have three seasons now on my '22 using a long sleeve Gerbing vest plugged into the front socket without any issues. I've tried adding the gloves a couple of times, which also worked, but prefer using the heated handgrips.
Steve
True, if the outlet is rated at 5 A, then it shouldn't be a problem (Vest is 4 A), but add anything else and it begins. Sounds like the SAE connection, from the battery, is the best bet, for multiple items.He is only running a vest. Add another item and the socket will shutdown at max power. You could probably run everything you wanted if you kept the heat setting low. I think it uses PWM so it might not matter the setting if the gear is pulsing at max current if that makes sense not sure what the time factory is on the powerlet shutdown.
On my 05 RT, I bought a Blue Sea fuse box for accessories and used a relay off of the stock factory power outlet to turn the panel on. I think I paid like $30 for the box. There are more elegant solutions available. If I was made of money, I'd install a hex innovations controller.True, if the outlet is rated at 5 A, then it shouldn't be a problem (Vest is 4 A), but add anything else and it begins. Sounds like the SAE connection, from the battery, is the best bet, for multiple items.
Steve
