Power Socket ??? '23 RT
Motor32
Motor32
I'm trying to find out, how many amps is the power socket, below the right side glove box is rated for? I want to plug in a Gerbing vest and gloves and just want to make sure I don't fry out the wiring, I couldn't find it in the manual.
Thanks for any help.
Steve
You probably won't fry anything, but the CanBus will probably shut it down if my GS is any indication.
I believe it's only 5 amps. I cant run my jacket and gloves. I just use the battery tender plug that is connected directly toy battery . It came with a 7.5 amp fuse and I replaced that with a 15 amp fuse as I have for years on all my bikes and it works great. It is actually a better place to plug in , at least for me. You wont have a wire coming out of the dash area to get in the way of things
Yes- I recall being told 5 amps as well. Morton's in Fredericksburg, VA actually disconnects the front port and wires it direct to battery with a 15 amp fuse as part of their pre delivery service. They were like- "the OEM CAN-BUS will charge a phone (for now).... that's about it". Forget about heated gear and all that.
The CAN bus doesn't shut anything down; the power distribution module (ZFE on my Hexhead) controls the electrical output to things like the aux power sockets.
Good points. I have a Gerbing vest 4 A, gloves 2 A, and socks 2 Amps, and will need at least a 7.5 to 10 Amps fuse. Maybe hooking it up SAE connection from the battery, will be the easiest.
Steve
Steve
I got a socket mount from Touratech on my GS that puts a new fused outlet on it. I replaced the dash outlet that wouldn't power my jacket with a dual USB outlet I got on Amazon for like $22. It has the exact BMW harness connector and plugged right in. Perhaps there's a similar battery relocation set up for your bike? Maybe something like this? https://www.motorcycleparts-hornig....ries-Paint-protection/Extra-power-socket.html
Yes- I recall being told 5 amps as well. Morton's in Fredericksburg, VA actually disconnects the front port and wires it direct to battery with a 15 amp fuse as part of their pre delivery service. They were like- "it will charge a phone (for now) that's about it".
That's a good idea, hooking the outlet directly to the battery, and bypassing the Can-Bus. Maybe another project to do.
Steve
Steve
There has been many threads on these outlet deals. Another problem seems to be initiated in the stock outlets is trying to use the outlet and one of the fancy chargers to maintain the battery on the bike.
SAE connector direct to the battery, appropriately FUSED.
I also have the Gerbing coaxial connector as well.
Can’t have too many well installed outlets. :bliss
Powerlet sells socket/fused battery connection kits with various lengths of wire.
Info: The '23 RT's socket hole has a slight "D" shape which ends to be trimmed to receive a Powerlet socket. On my '23, I used a step drill bit to carefully remove the flat part that blocked insertion of the replacement socket, *without* making the hole any larger.
Info2: The nut which secures the socket on back side of the panel is 22 mm.
A semantic distinction without a difference. The CANBUS is the communication that network that communicates with the ZFE and without it the ZFE would do next to nothing.
THAT should be the end explanation when people start the CANBUS/ZFE debate. :thumb
Steve
FWIW: I have three seasons now on my '22 using a long sleeve Gerbing vest plugged into the front socket without any issues. I've tried adding the gloves a couple of times, which also worked, but prefer using the heated handgrips.
Thanks, this sounds like the way to go.
Sreve
Thanks for the info, sounds like on your bike, it's never been an issue, interesting.
Steve
Steve
He is only running a vest. Add another item and the socket will shutdown at max power. You could probably run everything you wanted if you kept the heat setting low. I think it uses PWM so it might not matter the setting if the gear is pulsing at max current if that makes sense not sure what the time factory is on the powerlet shutdown.
True, if the outlet is rated at 5 A, then it shouldn't be a problem (Vest is 4 A), but add anything else and it begins. Sounds like the SAE connection, from the battery, is the best bet, for multiple items.
Steve
Gerbing's website says it pulls 4.5 amps, so a 5 amp source is going to be quite marginal.
Be advised that when it's first turned on and the wiring is cold, it could easily pull more for several seconds.
Pulse-Width Modulation of the heat via the controller may reduce this...
Steve
On my 05 RT, I bought a Blue Sea fuse box for accessories and used a relay off of the stock factory power outlet to turn the panel on. I think I paid like $30 for the box. There are more elegant solutions available. If I was made of money, I'd install a hex innovations controller.
