blockade
No! I took a closer look and saw that the lines were crossed! Not sure when that happened. But I checked again to see what the flow looked like at ignition on, and at idle. No flow! Not a drop!The top line is the return. That means the fuel should have been coming from the Male QD on the left, connected to the short hose, that's connected to the plastic fuel distributor line. Was that it?
Based on what you've measured in the TPS, it is fine. I will suggest some O2 sensor measurements next.
Sent from my 0PJA2 using Tapatalk
