blockade
Hi Folks,
I have been scouring the internet, this board and every other I could find, to get some information or ideas on what could be happening with my bike - a 2004 r1150r 2-spark with about 20k miles.
My issues started with a bad battery. According to the local parts shop that tested it it had a bad cell. I grab a new one from beemerboneyard and the bike ran fine for about a week after swapping it out. The issues started with a surging (at 1500 RPM) and trouble starting it up, which I seem to have cured with an injector soak. I was due for a valve job so I started with that. I'll list out all of my diagnostic steps to date, I will admit that I am pretty new to the oil head so don't feel like you're insulting me if you suggest something obvious that I could have missed or could have screwed up when performing a piece of maintenance.
Another symptom I have observed - holding the throttle at 2k rpm I can watch the tach fluctuate anywhere between 1.8k and 2.2k. It's not a violent fluctuation but it is noticeable when I would expect it to just hold steady.
In order:
I will readily admit to very little expertise when it comes to electrical systems - shocked the hell out of my self testing the lower plugs - however I do have a volt meter if you can provide me any guidance on what I should check, values, etc. I realize that my test against the Stick Coils is not the most effective but have no idea how else to test. I also suspect the HES, but my symptoms don't seem to point to the common HES issues (namely random stalling and hard start/no start).
I've got an appointment with the local BMW Stealer next week - would love to be able to resolve this before then, preferably before this weekend.
In order:
- New Battery
- Reset TPS by turning ignition on and opening/closing throttle three times.
- Valve adjustment (first time doing this myself, however I found it to be very straight forward)
- Ran bottle of Techron through the tank
- Checked all lines/connections from tank to fuel system
- spark plug check (visual)
- spark plug cleaning (using hot lemon juice and a brass wire brush)
- Throttle body balance (used a homemade manometer that I have used successfully on other vehicles)
- spark plug replacement
- Stick Coil/Coil test (used a "spark plug tester" from harbor freight)
- Ran second bottle of Techron through the tank
- Reset TPS by removing fuse #5 and opening/closing throttle 3 times with ignition on.
- O2 sensor disconnect (unplugged and ran the bike without the sensor)
- Cat removal/reinstall
- Injector cleaning (soaked in Techron overnight)
- Check for Vacuum leak by spraying WD-40 on all vacuum lines/air intake joints
- Used DVM to check TPS voltage
- Disconnected top fuel line disconnect (above right throttle body) to check return fuel flow - no fuel flow in line
- Disassembled Fuel Tank, found split in in-tank fuel line between fuel filter and external lines.
