Exactly. If I remove my pinlock I always put a new one on. Once removed it doesn't seem to seal as well.Year around. I have found that the process of removing and reinstalling, along with handling and storage, can reduce the effectiveness of the seal.
I have found that the Pinlock insert on my Shoei NeoTec seems to increase the distortion of images through the shield. The ventilation in the Shoei was high enough that I didn't need the Pinlock this past Winter/Spring riding season.
I never noticed any distortion using a Pinlock.
I keep two shields for the Schuberth-- one with pin lock, one without. I find it easier/faster to change shields than disturb the pin lock. And once warm weather hits, the pin lock pretty much stays at home.
Best,
DG
Thanks for the input. It's a new Helmet so I'm going to try it for a bit before I put the Pinlock on. So far so good. It's an HJC RPHA Max, if anyone had any questions about it I'm happy to answer.
The ventilation in the Shoei was high enough that I didn't need the Pinlock....
