Dear fellow MOA'ers, I have some puzzling issues with my R75/5 carb idling and synchronizing. I have read as many journals and how-tos on carb synching and adjustment before attempting and yet, I still have issues, hoping you can help shed some light:
A bit of background, mine is a 1971 R75/5 that i had purchased a couple years ago in hope to restore to good running condition. The bike had been sitting for many years by previous owner and when I took over, I worked on it here and there and managed to get it working and is ridable but it has inconsistent rough idling. I decided to have my carbs professionally rebuilt by Bing USA. This weekend I gave the bike an overall tune up treatment by changing out the plugs, new contact point, adjusted all the valves, timing etc. For the idle mixture screw (located at the bottom of the carb), I had it set to one full turn CCW from full right as per recommended setting. The bike started instantly which I was happy. But then I noticed a few things:
1) During cold start, the bike feels really smooth and nice engine sound. After 10 min warmup ride, I came back and tried out the shorting method, the left side shorts out as expected, but when I tried to short the right side, it almost seems like the shorting never happen - what I mean is, the engine reduces RPM ever super slowly and it feels almost unnoticeable, like I did not short the right side spark plug at all - I cannot imagine that it is normal? Can you tell me why that is ?
2) after fidling with the synchronization - honestly I don't think I did any better for the engine; I went back out for the test ride (low to moderate speed only). The bike rides well but my idling is super low at full stop, in fact, the engine would stall if I do not blip the throttle up. So I proceeded to adjust the top screw idle stop but then sometimes, the idle would bounce up high - All to say that it is very sporadic idling
3) When I got back and checked the spark plugs, the plugs looked really black with soot so I think my fuel mixture is way too rich on both sides .
What do you think I have done wrong? or my next step should be?
Your help is appreciated.
Henry
Henry
