Hi All. I am hoping you can share your wisdom with me. I have recently refurbished my 75 R90 including a complete carb rebuild. I have set the idle mixture and idle speed. At idle the motor purrs! The throttle seemed sluggish so I took the carb tops off and carefully reset the needles to the second notch, measuring to check they were the same.
My issue is balancing the throttle response at aprox 1500rpm. I have to take the right side out about half or more of the cable adjustment to balance. The left side is screwed all the way in. The bike seems to run and accelerate done this way but it seems odd I need to take the right out so far. Anyone have any thoughts or ideas?
Thanks in advance.
John
Victoria BC
Thanks in advance.
John
Victoria BC
