davidcboyer
Greetings. I’m a long time BMW rider and MOA member but new airhead owner. I rebuilt a 1974 R75/6 with 61,000 miles - notably for this question - new rings, honed cylinders, rebuilt carbs and electronic ignition (EnDuraLast). Compression and leak down test are favorable after the top end rebuild. The bike operates great - starts easily, good power, smooth throttle through the range. My question - I have about 500 miles on the rebuild and I am getting about 33 mpg with 2/3d’s highway at 60 mph and 1/3 city. Seems like I should be closer to 50 mpg? On the carb rebuild I kept the original needle jet and jet needle and put the clip in the 3rd position from the top of the needle. The plugs (see pictures) show some tan on the top of the insulator and dry black lower on the insulator and on the threads. I balanced the carbs manually.
What would you do for next steps on gas mileage? Should I lean out the midrange by moving the clip on the needle jet one step up? Should I have replaced both the needle jet and jet needle at this mileage? Is this possibly an issue of balancing carbs with a balancing tool? The bike is a joy to ride but I wonder about long term issues if I am burning more gas than needed.
