Add on Electric Shifter
Electric shift can be pretty simple.
It is also fairly easy to mount a hand shifter to most BMW models. In a nutshell you need a handle with a knob, and an "L" leg on the bottom end where you mount it to pivot. Then connect the L to the transmission shift shaft and lever with a rod.
A for and aft motion at the top will be an up or down motion at the L. Bob Mutchler has such a setup on his R11XX sidecar rig. This is not a really good picture but it is the best I have.
