rawhites
Member
On this sat-for-30-years bike project, I completed the initial rehab work: cleaned out gas tank, replaced fuel pump & lines, replaced steering bearings, front & back brakes, greased splines, new fluids.
Now, to the surprise of few, it won't start. The starter turns, the fuel pump purrs, and the headlight dims when I crank it. But no ignition. The tach barely blips, almost no movement. Maybe I have a spark problem? (I tried the Chris Harris trick of priming the cylinders with some motor oil. Didn't do the trick)
I've ordered a new battery since this one may be defunct after sitting too long over the winter. Off the charger it starts at 13.14V and settles at 12.91. With the key on it dips to 12.47...and drops slowly. When trying to start, it drops to 11.3. And then recovers to 12.3 V....
Once I get the new battery, any suggestions for troubleshooting protocol?
(The clutch is also stuck, but that can wait for another day
