taran1900
Member
This worked on my 15'.........
Your '15 is not my '19.
Apparently not…….I had exactly the same symptoms and what was outlined worked and continues to do so a year later . Thought that affirmation might be helpful. Sorry, my bad.
I may not have been totally clear. Sorry if that was the case.
The throttle reset process does not seem to be working for me anymore. I have tried it several times recently with no change in symptoms which is it turns over and over the first time either not starting or starting after four or five seconds on letting it go.
When I'm not riding the bike is on the battery maintainer and when I attempted to start it yesterday it was a 100 degrees in my garage. So, battery state and temperature have no bearing on the symptoms.
When I did my 12k service I checked the cam timing. Perfect. Valve clearances, perfect. Cam lobes, perfect. Spark plugs. Perfect.
I have verified that the battery cables are tight. I have checked the connectors to the throttle bodies and injectors to makes sure they are snapped in and snug.
I have run fuel cleaner to get any water out that might has condensed in the tank during the periods when I'm not riding. No change.
The only thing I am left with, is crappy software. Yesterday I took a video of the starting attempt. During the video I showed the battery maintainer and that all was green before attempting to start. So tomorrow, I am going to visit the dealer and show them the video and say "you fix, please". I'll report back on how things go.
Hopefully they get to the bottom of it for you. It was funny, mine started playing up right after a service at the dealership. Don’t know if it was something that got messed in my parameters when they interfaced with the ECU. Sounds like you went down basically every avenue, time for the mothership.
And the flap squeak has magically disappeared. I think they may have lubed it for me and forgot to mention it
Yeah, I'll post some updates once I have them. My regular warranty expires at the end of this coming November but I got a four year extended warranty for big ticket items like the exhaust and other various uber expensive bits. Last week I received my can of spray anti-seize. Hopefully the spray can penetrate deeper than it does by brushing it on. I use anti-seize on the muffle exhaust manifold connection every time I remove the muffler to change the rear tire.Definitely keep us posted on the the flapper valve squeak. I had mine resolved twice by the dealer(s) and once by me; it did not last long as the noise did return on mine. When I lubed the flapper shaft, I used copper anti-seize. It lasted a few weeks. I wonder if I should have used a higher temp rated anti-sieze/lubricant (thought I did.). I used something pointy and small to dab the lube in the shaft area, which seemed to work for me, but the valve cannot be taken apart to properly repair it. Boxflyer had his valve fail and the whole exhaust assembly need to be replaced. Yeah.
Good luck!
