I went out to fire up the r1150r this afternoon, and hit the starter button - no click, click, click - nothing. I don't hear the fuel pump whine either. I tried jump starting it, still nothing. Lights, clock, horn, brakes and all other electric circuitry seems to work.
I replaced the handlebar risers yesterday, but didn't start the bike before or after until I tried today. Could I have worked a connection loose underneath somewhere when I had the bars off? I looked hard and couldn't find anything that looks as if it came disconnected, and I had the fuel tank off to charge the battery and replace the air filter.
I charged the battery all day - still nothing. I got concerned when jump starting it didn't work either.
Any hints? I'm capable of some level of maintenance myself, but anything that gets too detailed I'd rather leave to the professionals.
I think when you put the bar risers on you stretched and broke a wire going to the Kill switch. We could walk you through a series of tests to find out what's broken. You will need a DVM at some point. Would you like to go that route?
I would guess you broke either a kill switch or start button wire.
What is the voltage of the battery?
What is the voltage of the battery under a load?
The answer will probably solve the problem.
Last year I had the same problem. Replaced the battery with a PC680. Solved the problem. Not uncommon to find a dead battery come Spring. Especially, if you didn't have a battery tender on it. A cold Winter can separate the plates. The result is a battery that has some energy, but not enough to power up the bike. You can try to recharge the battery until the cows come home, but you will have the same results you have now.
Another tip that the battery is close to reaching the end of it's life, is when the ABS alternating lights come on when you try to start the bike when it is cold. The PC680 runs at a higher voltage that the ABS system likes.
The image speaks for itself. Check out Relay #1. BMW got relay "happy" with the oilhead, which isn't a bad thing.
I see you are new to the forum. Welcome to the forum. Do a search on ABS alternating lights. That way we don't get off on a tangent. The voltage issue of the ABS system has been discussed on this forum so many times.
Let's stick to solving the OP's problem, which most likely is the battery.
I think you have to take a serious look at what was touched, or nearly touched when you were working on the bars.
Something happened right there.
You just have to find what it was.
dc
I replaced the handlebar risers yesterday,..
Thanks to everyone for all the insightful info. I think I'll go the route of checking the wires into the kill switch/starter button. I'm not thrilled with taking all that apart for fear of making matters worse, but what the heck, it doesn't start anyway! So if you have some steps to take, I'd sure appreciate it.
I'm thinking about taking off early today and coming home to work on it again. First step will be to thoroughly inspect all wires, and if necessary, figure out how to take apart the kill switch housing.
Tangent: Cele is right here too; the diode "across" the relay is only there to prevent what is called "Inductive Kickback" from the relay coil - when voltage is removed from it, like an ignition coil, the stored charge needs a place to go. And, this charge will have the reverse polarity of the "applied" charge. The starter probably wouldn't be damaged by this, but the computer sure would be. The "other" diode is part of the "logic Or" starting circuitry which Roger has already commented on.
you are giving up. I think this would be a blow to everybody that is involved. Generally no crank no start conditions are among the easier to diagnose and the most satisfying to repair..
........ I don't think it can be jumped from less than a running vehicle.
somebody help me out here. i have heard that jumping our bikes from a running vehicle is a fabulous way to fry some portion of the electronics- FI system, Motronic, etc.). i've jumped bikes from cars, not running, on bikes with weak batteries and never had a problem.
i wanted to get this out there and confirmed in one direction or another- is it safe, or is it ill-advised, to jump from a running vehicle?
I don't want to get off on a tangent. But, the PRIMARY purpose of the diode is to prevent voltage spikes (clamping). From the reverse polarity surge, you can have the voltage jump up over 200 volts. There are two ways to use the diode. The first is to run it in parallel. The second way, is to run it in a loop. BMW used option #2. This allowed them to use it for the neutral and gen indicators. The second way also reduces the voltage spike. Don't be confused by the indicator lights and the non-switchable pole.
There are two reason to remove the voltage spike. The first is to protect the computer from a large voltage spike. The second is to allow the starter manufacture to use a lower cost copper wire. The maximum voltage level will be determined by the copper alloy used in the manufacture of the wire. That is why you see starter relays on almost all vehicles today. Older vehicles starters could handle the higher voltage because of the better and more expensive copper alloy used. Maybe you haven't noticed, but copper has become very expensive. As for the computer, I am sure they have MOV's and diodes inside to protect it from other outside voltage spikes like static and voltage fluctuation within the electrical system.
Otherwise, BMW could have used a cheaper setup that would have done the same thing.
I've found 12V to be 12V and the only real problem is doing the jump with some sort of bad connections.somebody help me out here. i have heard that jumping our bikes from a running vehicle is a fabulous way to fry some portion of the electronics- FI system, Motronic, etc.). i've jumped bikes from cars, not running, on bikes with weak batteries and never had a problem.
YesCommon misconceptions that are circling the web presented by half informed people is that car jumpstarting (because it it bigger) will damage the bike (because it is smaller). Running voltage of any 12 V system alternator is ~14.4V. You could jump your lawnmower with an aircraft carrier (trying to be visual) as long as they are running 12V system. Actually you are more likely to damage the donor vehicle if the charging system is unable to sustain the additional load of (potentially) shorted battery. However, after jump start, dead battery can potentially damage the alternator, again due to the additional load put on it. Hence it is not recommended to jump a vehicle that is completely dead, but I have also done it many times without damage. I would try to restrict the load by removing light fuses to relieve the system of unneeded loads until the battery is charged.
