J
JAMESDUNN
No problems with the oil light does go away after bike starts. Yes push rods seals are on the list and all the gaskets that will go along with the rod job.
Do not forget to drop the oil pan and install a new gasket. The oil pickup may and probably will need to have the bolts tightened. Clean everything up while you're in there. Use a newer fiber gasket, although these may be all that are available now.
