R100GS rear wheel mount problem
This has gotta be a dumb question.
Removed rear wheel to do some work on the exhaust. Rear wheel came off no problem but I cannot get it mounted. It won't make it around the circumference of the brake shoes.
Should I be attempting to mount the wheel with the shoes in the out position or pushed in towards the swing arm? (Neither is working.)
Is this a brute force job?
What am I missing here?
Thanks in advance!
The brake shoes are rocked inward. Pull them out so that they are square, and the wheel will slide over them.
EDIT: I always back the adjuster off 10 or 20 turns before removing the wheel.
Thanks, Anton. Worked like a charm. Having only removed rear wheels with discs so far this was a good learning moment for me!
