R1200RT - Cleaning the inside of the windscreen
stinkypete
(2016 R1200RT) This is a question so basic that I am feeling quite foolish for asking, and am showing my "newbie" status. :dunno
When the bike is parked, the screen returns to it's fully "down" position, and only moves up when the bike is moving. Therefore when the bike is off and parked in the shed, I can't access the inside of the screen to clean it, and the inside only seems to be accessible once the bike is moving, which is not an appropriate time to pull out then rag and cleaning products.
Is there a setting that I have not found, and how to I get access to the inside of the windscreen to clean it??? :scratch
I can raise my 2016 RT windshield when the bike is not moving! I just turn on the ignition and press the button!
OK. Now I feel like a real idiot, but thanks for pointing out the obvious. :doh I'll go and quietly hide my embarrassment for a while, and not ask any more questions.
After you have washed screen and dried it best as you can, I suggest a leaf blower to blow the rest of the water out of the nooks and crannies, works for entire bikešŸ˜Ž
Jim
stinkypete, with the windscreen raised you can certainly clean everything you would normally be looking through and most of the rest, but not quite all.
About 1-2 times per year I remove the windscreen entirely and clean the whole thing. It is really easy and quick, just 4 Torx M5X20 screws and that's it.
+1! to Alan Coles. Take a couple of minutes a week, get the screen off and really clean the whole area...screen, dash, etc. You know you'll feel better afterward...
Not to be a stickler or anything but there actually are 6 screws that
need to be removed. 2 are under the black plastic bits.
And yes, removal is the best way to clean the shield and the area
under it. If youā€™re gonna clean it, might as well do a thorough job of it.
Cleaning the inside of the windshield
Mine only has 4, maybe they change by year. I also use rain-x on the part you can't get to and it seems to stay a little cleaner a little longer. Or maybe it's just my imagination. It does seem to reduce the amount of bug guts stuck to the outside though as well...
Jerry
There is a product which I'd say is mostly for those riders who are touring. Here is the URL for the Amazon listing for it: https://www.amazon.com/Boners-Bug-B...65&dpID=21SXzvQPgkL&preST=_QL70_&dpSrc=detail
On the one hand I think it's dramatically overpriced at $12 for two pieces of cloth about a foot square. However, I made the plunge, bought the Boner's product, and like the results. I showed my pals at the Fontana Getaway how these cloths worked. They pulled those pesky NC and TN bugs off our shields and even got close to those lower corners of the RT's shield. Results were good.
Of course, nothing beats taking off the shield on the Wethead RT, but in a touring situation, this product seems to work well.
Windshield
I wash the bike with water and soft sponge then use a Honda spray plastic cleaner and polish which I found is Carnuba wax. this seems to work well on the glass also, Any comments on a windshield only cleaner?
I also use rain-x on the part you can't get to and it seems to stay a little cleaner a little longer. Jerry
I was always advised to Never use Rain-X on plastic as it will permanently damage the surface. Fine on glass not so much on any type of plastic.
A.
A.
Rain-X makes a version of their product specifically for plastic and has done so for a few years at least.
I didn't know you couldn't use it on glass. Maybe that was the older stuff. I use this on my bike, my truck and my wife's car. It says it's OK for plastic on the bottle and the website. Only downside is it takes a bit of time to do.
https://www.rainx.com/product/glass-water-repellents-cleaners/rainx-xtreme-clean/#.WxfnnkgvxPY
Jerry
Thanks guys - I'm not aware of that version of the product being available in Australia - will look around.
Regards,
A.
