Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
Correct me if I am wrong but that technically looks more like a device to prevent fuel from exiting the vent line in the case of a tip over, not the fuel cap.
OOOPS - My error:
From the factory, the "vapor vent" line is connected (through the round plate) to the charcoal canister, which would be damaged (flooded) by the entry of liquid gasoline. If the canister is removed, then that line is typically routed down with the filler neck's water drain.
So, it's not to prevent fuel escaping if the bike is dropped, it only tries to save the charcoal.
That valve is called the rollover valve in the OE service manual.
It's called a safety valve on the parts fiche.
Normally it vents the tank. When the bike takes a dirt nap, it stops fuel from coming out the vent hose.
Euro & Canadian models did not come with a charcoal canister.
