TFT default radio volume R1250RT '23
I have to add a note about the Schuberth SC2, the volume won't turn up load enough at speed. The Sena 50S had a software update that has Audio Boost. Sorry to rant but I'm not happy with Schuberth slow response to this issue, the software update in the Sena 50S has been out since September 2022. At this time I won't buy the SC2 again.
I have no issue with the SC2 volume levels. Make sure the phone's media volume is set to max as well.
My biggest complaint with the SC2 is the battery life of the remote/control unit, beacsue
- It doesn't turn off with the main unit, so I forget and leave it on all the time and kills the battery
- That battery only last 5-8 hours max anyways, and I have to carry a supply of replacements
It shouldn't have been too hard to run a power/control lead from the main unit instead of the control being wireless and powered by a standard watch battery.
Wow, that's really short.
We have the SC1 and on trips I only have to charge the helmets every other day.
Will the intercom work after the remote dies?
Thanks Irtax, I do have my phone volume at max still not loud enough at speed. I ride with foam ear plugs. Funny I don't have a problem with battery life, it always make it through the day but I'm not using it to communicate since I have the volume issue. I can hear the XM radio but just needs more volume. If I remember correctly the Mesh uses less battery then Bluetooth but you may want to check me on that. I understand Mesh is the only way to go, much better then Bluetooth.
It was a nice fix when they added the WonderWheel, it only took 8 months from the release for the Sena 50 units to get into the SC2.
I have a fix for the volume issue I've been having with the C5 Schuberth SC2. The helmet speakers just aren't loud enough at speed, Sena makes a earbud adapter, it allows you to plug in 3.5 mm earbuds (I have a custom pair I used with my Sena 20s EVO). Sena part #10R-A0101 . The volume goes way up, not sure why I didn't hear better with the helmet speakers, they seem to be in a good location over my ears (I ride with foam ear plugs). 3.5 earbud plug.jpg
