Stebel Horn Install on a KGT 1300
Before mounting the compressor connect the provided wires to the postiie and negative connectors
After the connectors are placed mount the compressor as the instructions state.
Close up view of the securing sequence
Creating the Horn Trigger
Insert the provided ball with pin wire from the kit in the GREEN wire connection.
NOTE the picture shows the pin partially inserted for pictorial purposes - SIT THE PIN fully for actual application
Seal the connection with some heat shrink
To properly seal, insert the shrink tubing into the connector
This next step is not called out but I taped the heat-shrunk tubing with friction tape
After the connection was taped it is now time to route the wire to the relay.
Shown below is how I routed it
I went up the side of the main harness
Across the battery mounting area
Then down into the ABS Control area to the relay
Across the battery area - the green arrow shows how I routed it in the hole for the J-Nut
Some wire management detail by the horn connection area
As the trigger wire is black and there is still more wiring do to, I quickly threw on some white heat shrink tubing for identification and noted the end.
I will shrink the tubing later once the final length is established
Mounting the Relay
The relay shown with the arrow is not OEM equipment it is the relay for my Centech
The green highlight is where I am mounting the relay for the horn.
Tools used are a T30 torx and a 10mm wrench
Detail of relay mounted.
Note 1 - the hole where the bolt goes thru is a little small, you will need to run the bolt thru to ensure it fits
Note 2 - the bolt is intentionally mounted upside down (by me) this is to provide the surface area of the washer on the tab of the relay
I decided to create my own power harness as I did not want to use black as a power wire
Connecting the power for the horn from the Centech
This special connector provided in the kit, connects the grounds of the compressor and the bike (from Centech) together
The relay is connected
Please note at the time the length of the control wire (horn) was known i shrunk the white tubing
