It appears the NHTSA may not be as efficient as they could be. I've just posted the below comment on their web site. 6/4/2012
Mr. Strickland,
I've found a design problem in the way in which NHTSA gather's faulty vehicle information. It appears that filing the complaint by vehicle make, model,year, does not provide an accurate database of "component" failure. This is because a common component can be used in many makes, models, and years of vehicles.
Example: BMW Motorcycle's "final drive" assemblys.
ref: ODI - 10460182 or ODI - 10439549
Both of these are the same component failure but NHSTA would not see them as such because they are from different vehicles, years, and models. These failures I'm told are listed as ball bearing failure, crown or spline, failures, etc. None of which are cross matched in the NHSTA system and therefore NHSTA would not see the pattern of failure.
Secondly, a NHSTA representative told me that NHSTA notifies the manufactures and then drops the ball. In other words, there is no followup initiated on the part of NHSTA with the manufactures on individual complaints. This leaves it up to the manufacturer to respond, ignore the complaint, or simply trash it. The NHSTA would have no way of knowing if NHSTA does not incorporate a followup process on these complaints.
Thirdly I am including a post from the internet which describes this particular failure and the lack of resolve on the part of NHSTA with the BMW manufacturer:
LINK: http://www.advrider.com/forums/showthread.php?t=761531
After over 145 individual complaints filed between April 2001 and August
2011, the NHSTA has finally opened its first official investigation into the
failure of crown gear bearings on BMW models equipped with the Paralever
style final drive. NHSTA investigation DP12001 opened 1/20/12 is centered
on 1999-2005 K1200LTs for now. But, if the findings are what we all believe
they will be, the scope of the investigation should be expanded. I found
the only way to get NHSTA to listen and focus was to pepper its director,
David Strickland, with repeat letters as well as inquiries from WA Senator
Patty Murray who chairs the subcommittee over funding for the NHSTA. If
you have had a final drive failure on your Paralever equipped BMW, and have
NOT already reported it to the NHSTA, I urge you do it now.
You will need your VIN, (est.) date of failure and mileage. State your
model as well. While they should be able to identify from VIN, their data
was wrong 50% of the time. Specify if gear oil leaked.
