simonak3000
I have discovered some rear wheel play on my newly aquired R1150GS 2003 with 48700mi. I was thinking of doing a full final drive rebuild but after doing some research on this sub, i found out that in more than a couple of cases, its not the big crown wheel bearing that is causing the play, but the two smaller final drive to swing arm bearing that go bad. My question is: With the rear wheel raised, is there a way to be sure of which bearing is going bad? Is there a specific technique used? If I dont have to open the final drive and change the crown wheel bearing then I would be very happy and could wait for a more opportune moment. Thanks!
