Your race-bred expertise and mods are very intriguing... but I feel like every time I start going deep into the mods on a bike or car I end up someplace where I'm challenged to get the package right and wish I'd just left well enough alone. My only material mods beyond the Sargent seat [ultimate non Ohlins mod] is a Danmoto cat elim that came installed, along with a peg/controls lowering kit [also installed by the previous owner].Just installed AF-XIED, (gen4) set on #7. Put a 100 miles on it and see stronger throttle response and a "howl" from the engine I've never heard during wide open. Hope the off throttle and slow speed stuff gets better. This was the wire-it yourself version. Not too hard. O2 sensor had 31k on it so left that alone.
It does start and idle better.
It works MUCH better than the Booster Plug. The initial "adjustments" the Booster Plug makes are learned by the ecu which then adjusts the FI back to the factory parameters.R1100s AF-XIED, (gen4) update .... I'd recommend it over the Booster Plug method.
...AHAA! I thought I was imagining things with the Booster Plug, like it worked but now it didn't feel like it still did. Which was why I sprung for the AF-XIED.It works MUCH better than the Booster Plug. The initial "adjustments" the Booster Plug makes are learned by the ecu which then adjusts the FI back to the factory parameters.
When I put the GS torque arm on my S (highly recommended) I had to fashion small 3mm pads to fasten to the centrestand feet in order to get the back wheel off the ground. I think whether or not you need them depends on the size and brand of rear tire one is using.
Yeah, as referenced in option 2 - but I'm not one to remove my own valve covers. Will leave that to the pros.
My local guy has a trick with teflon tape that sounds like it should keep me moving until I can get these parts in hand and do this simple fix. Thereafter I will see if I have the guts to attempt the entire scenario outlined by @pauls1150 - or have someone do it for me.The fix is simple. There are TWO - yes two - O rings at that asssembly. One is on the twist-off cap. The other is between the black outer ring and the aluminum head. Replace both with new O rings and you will be good for a year or two. Then repeat!
