Along those lines-It's just four bolts and two gaskets (the flat "outer" gasket, which IS directional, and the "cup" for the center post) per side... easy peasy. Maybe a little oil mess if you aren't prepared for it (a drain pan under the head).
But we do appreciate your willingness to admit some limitations (a la Clint Eastwood).
Teflon tape here just seems "iffy" to me... on the outer cap, you chance having a small bit drop into the oil if it breaks off (as when adding oil), and on the inner seal, you cannot really see and verify that the teflon has seated properly and that any excess isn't hanging down.
By the way, you can leave out the @ everywhere unless you're directly emailing somebody...
One needs to be careful with Teflon tape in fluid systems. If a piece of Teflon tape breaks free, it’s not prone to dissolving, it’s prone to getting “wedged” somewhere in the fluid passages. Sometimes it becomes a problem, sometimes you find it in a fluid change.
