Is it possible for there to be engine block rot? There’s a spot on the engine (clutch side) above the Id plate and below the frame joint where i found a layer of crud. When I tried to clean it, it felt soft and as I poked at it, it started to feel real soft. Is it possible that the engine block has a bit of rot? I assume not, but maybe a hole that was filled?
