Hi
Got a nice 73 LWB Green R75/5 toaster. Has 36k on it and was tuned up last spring and ran well when put away last fall. I completely drained gas and removed float bowls for the winter snooze. I recently filled it with 98 oct race fuel and went for my first ride since the winter snooze. Started fine, would pull strong, but was cracking up and intermittent when cruising along at 3500 rpm, and will backfire and pop a little when rolling off throttle. At one point it was stumbling and stalled out. As I was still rolling along I pulled out key and reinserted it and popped the clutch and bump started ok but had to limp home.
I have had a little trouble with the switch before so Im thinking its the key switch. Is there a way to clean the contacts on the switch. I repeat I want to clean the switch for now not replace or go deeper for now. Any info on cleaning for better contact is appreciated.
Brian
Brian
