D
dhgeyer
1996 R850R, but I bet the same is true for any bike with a cable actuated clutch from this generation. The manual says that, to adjust the clutch, you set the top adjustment to a set amount (12mm from adjuster to nut as shown in the diagram), and then do the actual adjustment at the other end. I've had two mechanics tell me that it must be done this way.
Can anyone think of any logical reason why this would be true? I sure can't. How on earth could the clutch actuating pushrod (too lazy to look up the real name of the part) know which end of the cable has been adjusted? All it knows is how far it's being pushed in. If the top adjuster isn't there to be used, why is it there at all? It doesn't make sense.
Not to mention that it would be a lot easier to get the right amount of freeplay with the top adjuster!
