DEFINITIVE method for replacing OEM rubber handlebar grips on Wetheads (LEFT/Clutch grip)
scott9999
Well-known member
Roadmap: 9/19/24: I’ve finally gotten around to finishing this up.
These posts only cover my experiment with the left side grip on a BMW Wethead RT. There are three parts, i.e. this original post, plus two updates.
Part 1 is this post.
Update #1 immediately follows this post.
Update #2 - Final (9/19/24) - Conclusion & results (much further down this thread)
It’s not as difficult or scary to remove and replace the rubber grips on a Wethead, as my first two posts indicate, but it IS a chore. Of course, it’s easy-peasy of you buy a new OEM grip. Overall this effort was a failure, but since I found no specific information on the internet by anyone who's actually tried to do this task, I decided to give it a go. I still think it's possible to do this repair to a BMW Wethead; and since I'm a glutton for punishment (and ...uh... a cheapskate), I'll probably take a shot at the ($350!) right grip over the winter.
The goal when finished:
(Well, actually the goal is to have this thingy fixed and re-mounted back on the bike's handlebars, but I trust you get my meaning. 😁)
So again, this post and Update #1, explain initial attempts at this repair, i.e. removing the existing rubber grips and replacing them with a very-good OEM by an Italian company, Ariete. Update #2 covers the conclusion, plus adds paraphrase instructions from BMW’s shop manual (with my own comments added), for replacing the heated grip with an OEM replacement.
Title Disclaimer: "Definite Method" is tongue and cheek, as in, "maybe ya definitely don't wanna be doing this ...".
BMW has, in fact, on it's Wetheads (and probably Shiftcams), embedded the heating element and unshielded connector wires into the rubber grip itself. Replacing it will involve shaving away the rubber grip, without damaging either the element or the delicate connector wires, and/or doing a bit of soldering, or other electronic repair.
But, ~~ IF ~~ you're a stubborn SOB, and you INSIST on replacing them, here's what you're in for.
First, research the cost of replacement before you tear into your grip. (Know the cost failure, before you fail. 🤔) For my 2018 RT, these are the two part numbers:
61 31 8 552 117 HANDLE LEFT - 5,5 OHM (from 08/14) $150.40 *, $116.28 **
61 31 8 552 122 E-THROTTLE GRIP - 5,5 OHM (from 08/14) $406.55 *, $315.77**
61 31 8 552 124 E-THROTTLE GRIP - 5,5 OHM (from 08/14) $430.83 *, $315.77**
Note: Part #124 is probably for bikes with cruise control - verify with BMW
* MAX BMW
** MSP (Europe based, no VAT, no duty, reasonable shipping)
I'd go with MSP from Europe, personally.
This is where I started. Six year old 2018 R1200RT, grips look fine, but are hard, shinny, and slippery. They need replacement, by something (Grip puppies, rubber washers, or .. here's a wild and crazy idea, NEW MOTORCYCLE GRIPS!)
BMW's engineers were flat out lazy, in not creating a viable maintenance path for a rubber wear item. NO motorcycle's grips, are "for the life of the bike". Forcing owners to replace the entire assembly, is akin to telling owners "Oh, yeah, that rear tire, it's replaceable as an assembly only. New tire, new wheel, and also everything attached to it even though they have nothing to do with the rubber tire itself, i.e. final drive, ABS brake caliper, ABS sensor ... etc.". Second, the part of this process that has really tripped me up, i.e. the unshielded, unprotect, probably 22 gauge connector wires, embedded into the rubber grip itself, is lousy engineering. I'm sorry, but one does not embed thin, unprotected wires, inside a replaceable rubber grip. Don't bother arguing the point. Either you think it's fine, or you're an engineer, or a owner with common sense, one or the other or both. This grip thingy is probably reason #184 why this is my last BMW, i.e. car, motorcycle, tricycle. The German's at BMW Motorrad are arrogant, lazy, and elitist.
But, I'm jumping ahead of myself.
Start with peeling away the old grip. There's more than one way to skin a cat, or in this case, a BMW rubber motorcycle grip. I tried to cut a thin line across the grip from end to end using a box cutter razor blade, but that tool quickly gave way to more exacting hobby knives. Work horizontally above the surface, hopefully gliding over the embedded heating element wires.
I attempted to work around the handle, again, skinning this grip the same way a hunter skins an animal. I lifted the rubber grip "skin", until the rubber stretched and stressed, then ran the blade across between handle and grip, severing the connection of that section of grip. Over and over, and over again. Lift, cut, lift, cut. And, this "animal" is still alive. No booboo's allowed!
Pro tip #1: These sharp razor blade tools will cut very nicely thru fine wire, just in case you're out in the field, need to cut wire, and don't have anything other than your handy, razor sharp knife on ya at the moment. (Or, in this case, DON't cut, nick, or ..ahh.. bend the wire. 🙄😖)
"Oops"
At some point, working from either the controls, or the end of the bar, you will run into thingy's that feel suspiciously like electrical connectors that don't appreciate sharp things cutting and jabbing next to them. That will cause some delays (maybe drinkin' too; certainly two extra strength Tylenol applied for me).
Pro tip #2: When you expose the area near control end of the grip, you'll see a fine Torx bolt, through the bar, out the other side, with a nut on it. If you remove that, the entire assembly will slide off the handle bar util you reach the maximum length of the attached wire bundle. The assembly can also twist around the bar, again, limited by the attached wire bundle, enabling you to reach the bottom of the handle & grip without trying to look at it from upside down, giving you a headache in the process, and possibly buggering up the wiring. (Don't ask me how I know.) Anyway, remove the screw once the top half of the grip is stripped.
We're on a roll here, boys, some limited success, but I think this is what we're after (see the first picture, top half mostly stripped). My hope was that getting the top half off, would allow me to start peeling the bottom half off. Nope. Every inch/CM of that grip is (probably, heat-) welded to the conductors and handle bars. You'll have to manually strip off every part of that grip. My theory of the case was, get the thing off, expose, identify, and protect the heating element and connecting wires, then use another type blade to scrap off as much of the rubber as I reasonably could without damaging ... stuff. Note that the top of this picture, i.e. near the control end, is still proving a problem. I'm hitting hard stuff, not the coil, and the rubber is again, just absolutely welded to every part of that handle.
I found (cut into, more or less) two connectors attached to the end of the heating element wires, which is when I really slowed down, and tried to cut around the edges, and ease the grip off, until I could find and protect the connecting wires. So, I managed to pull off part of this section, and found those wires. (Crap!)
At this point, I know that I'm in the sh*t on this project. Those wires have definitely been nicked, and are also definitely embedded in the rubber, i.e. there's no other way to strip that grip from the handle without running into, and probably causing some damage to those wires. Simply trying to pull the rubber away, would eventually yank the wires from the control connector (if I haven't already managed to do that). However, I've worked with some liquid wire insulation that I could potentially use to recoat these wires. If that doesn't work, I have some aviation rated 18 & 22 gauge wire that should work. Remember, whatever goes back under this grip will get hot. Second, any repairs I make, need to be minimal enough that the new grip will fit over it. (Yeah, I'm DEFINITELY, well, probably screwed.)
So, ahh, how was YOUR day? 😡
The following picture is pretty much the sum of the damage. I can tell that the copper red wire has been severed. And the black (kind of looks like it might have had a Teflon write wrapper, who knows), has been chewed on as well. The shiny things on top are the wire crimp connectors. My guess at this point is, if I'm gonna fix it, is to cut the connectors out, remove the original wires, and somehow splice new ones to the heating element wire using a new crimp connector, and probably splice it into the wire going to the plug for the switch (since I'm certain the plug these wires are connected to, is BMW custom, and I can't buy a new one. (No, I'm not real good at doing this electrical kind of stuff, but that's never stopped me from blundering forward and trying to, in the past.) Note, those two "lumps" that the wire's pass under, are almost certainly that, i.e. plastic bumps with a hole thru them for the wires to pass through, to hold them in place. Again, when you're blindly clawing thru the rubber, and come across those metal connectors, bypass them, and when you run into those two little hard points that you didn't really think would be there, you ... go get a beer.
By the way, the heating element wires are essentially one single wire, with a double "loop", that wraps around this other little raised knob thingy at the end of the handle grip. Bottom line: If you can figure out WHAT the heating element looks like (i.e. I've seen some video's about BMW heated grips, which look like a regular rubber grip slid over a round electronic circuit board looking kind of thingy, i.e. the heating element is a circuit embedded into a computer board, which wraps around the handlebar. This one ain't that), and figure out the direction and location of the first wire, the rest will pretty much be the same distance apart and running in the same direction, until you run into the connectors, cut the wires, and screw yourself over. 🤔😖 You pretty much just skin the rubber grip off, running parallel to the handle, scraping along over the wires without damaging them (much).
Obviously, even if I get this repaired and it tests for continuity successfully, I still have a ton of scrapping to do to clean up the grip, then I have to successfully install the new Ariete grips (which I am pretty certain, are compatible with the Wetheads).
Once you get to this point, you'll KNOW that you should never have started this, at least not without ensuring that neither Grip Puppies or the 200 rubber washer thingy that other use, both over the OEM grip, doesn't work well enough for you.
The most important "lesson's learned" from this effort is in the first couple lines of this post. Read it, then step away, drink something alcoholic, and read it again. Then let a friend read it to you, just to ensure proper reading comprehension. (No, not your wife or girlfriend, cause, how trustworthy can they be at helping you AVOID pain - get real, man! 🤣) There are alternatives to tearing your grip apart (i.e. "grip puppies", rubber washers, tennis racket grip sheath, etc.).
Update to follow.
Update #1: (Again, this stuff may be TMI, too much info, for most people.)
Update #2 - Final Conclusion follows later in this thread.
I've taken some pictures, but I don't think that they'll add more than I can describe in text. I've yet to figure out how to remove the multi function controller from the wonderwheel and the left handle. (Believe it or not, I actually DO have an OEM DVD manual, and have yet to look at the steering assembly, believing that BMW won't provide much info on what they consider to be a one piece assembly. However, that's not true, and the picture from the fiche helps some.) #5 consists of three screws which apparently attach the control wheel to the handle. I'll dive into the manual later to figure out how to separate the multi function switch (61_2999, though there about a zillion variations, very complicated picking the right part, but I'm not replacing it), from the wheel and handle. One thing is clear from looking at both left and right handles, is that there's a pigtail
One thing is clear from looking at both left and right handles, is that there's a pigtail attach to the handle, which includes a plug, which is significant in my attempt to repair my existing handle.
Unfortunately, it appears that it's not just the rubber handle holding the heating element wires and attached electrical wires to the handle. They appear to be embedded in some sort of glue or resin. I can scrape the rubber from the handle all day long, but when I scrape next to a heating element, it's like scraping through plastic or resin. The connecting wires, previously discussed, are embedded in the plastic handle (I assume that they are molded with holes for the wires to pass through) - see blue ink. However, while I can lift the clips attaching the heating element to the red and (black/white) connecting wires, I can't move those wires at all. It's as if they're glued, or embedded into the plastic. I had intend to replace the clips, connecting a new piece of wire to that plug hanging outside the handle. I'd also have to splice it to the switch at some point (i.e. I doubt I can remove it from the plug and replace it). Not sure at this point, how I'll do that. I was hoping to run a new wire from the existing crimp clips on the left, through the holes in those "bumps", and use a second set of crimp clips on the right side, to splice it into the OEM wire attached to the plug. Then cover both sides with shrink tubing, continuity test from the plug, and then put on the new grip. Now I may have to try splicing outside the handle near that plug, and I'm not sure I'll be able to reassemble the handle, wheel, and multi-function switch with an extra splice there.
At about $145.00 from MSP (including S&H), replacing the whole, dang left grip is starting to sound pretty good. On the other hand, if I want to fresh the right throttle grip, that's pricy, so at this point, I intend to attempt a repair. If successful, I'll take on the right side this winter, after the bike is in mothballs, and I have more time to play with this. (Yeah, I also have a set of grip puppies in house, "if all else fails", and maybe I'll just buy some heated gloves. Will be tons cheaper than replacing BMW's OEM grips)
Edit: As noted in Update #2 below, I found a pretty good price on the OEM replacement grip from the UK.
£85.13 ($112.64) from MotorWorks.co.uk, shipping and taxes included (no customs) to N. Idaho USA, in less than a week.
(Note: update #2 - Final Conclusion follows later in this thread.)
I too put grip puppies over the OEM grips after they started cracking. Although my GS is supposed to have the flex circuit heaters underneath, it just didn’t look worth the effort to try to replace the grips after considering the way they are designed.
Heckova write up! Gave me a headache on your behalf. :)
I installed Grab-On grip covers when I bought my bike. 50k km later they're still on and transfer heat as required.
Update #2 – final:
Grip Repair & Rubber Replace (review, results):
  1. I attempted to strip off the rubber grip from the plastic base, to replace it with an after market (very good, nearly perfect) clone from Ariete. I was partially successful. While removing the rubber near the inside edge of the grip, I found the connecting joint between the solid heating element wire, and the stranded wire connecting to the harness (via the multifunction switch). They are connected with a mechanical crimp (probably soldered, too). I was able to remove the rubber with only minor abrasions, which I am confident that I could have sealed with a high heat liquid wire insulating compound.
  2. However, the stranded wiring itself was severely compromised, with only a few strands remaining. The insulation BMW used was a hard plastic, and the stranded wire itself was really substandard in my opinion. I was forced into rewiring this thing. I had some aviation rated 24 gauge insulated wire in my stocks, however, it just seemed too thin for this purpose. I purchased some 20 gauge wire and copper wire crimps.
  3. Rewiring worked out pretty well. I had to pull have the heating wire element off to crimp the new connecting wires then strung them thru the appropriate holes in the grip to, taking up the slack while re-wrapping the heating element. Since my replacement wire was more bulky than the OEM stuff, I had to enlarge the holes in the plastic. I also did what BMW DID NOT DO, which is use shrink insulation around the joint, protecting the joint and wire. I believe that BMW installed the wire and crimp that was damaged bare, trusting the rubber grip to insulate and protect the wire.
  4. Here’s where it started getting tricky. I also enlarged the exit hole. You’ll notice a little square chunk just above the drill bit. That was moving, so I’m pretty certain that BMW laid the wire in the gap, and glued this filler piece to seal the wire into the grip.
  5. There’s only a 5/8” piece of wire between the grip and BMW’s OEM connector. That’s a problem when rewiring. Unless someone has a source on a replacement connector, it must be spliced into the new wire and reused.
  6. That connecting wire passes through the Multifunction switch and anchors with one of the three screws which hold the switch to the plastic grip handle. (The third screw hole is obscured near where the blue and white switch wires route. See the parts break down picture in my second post, i.e. #4 is the switch, #5 are the three T55 screws.) There’s no room to put a crimp or solder splice from the new wire to the connector, and still have it fit in that slot in the switch.
  7. I think it’s doable with a well soldered joint, by hiding excess wire inside the switch. However, that’s where I ended up failing. I cut the wire from the BMW OEM connector too short, and I didn’t have enough wire left to create a secure mechanical connection, before soldering the splice. I think it’s possible, but I just didn’t have the skills.
  8. I got close. However, my riding season was trashed because of the time spent on this and other projects. So I bought the OEM replacement.
  9. SO darn easy. £85.13 ($112.64) from MotorWorks.co.uk, shipping and taxes included (no customs) to N. Idaho USA, in less than a week.
  10. By the way, the Ariete grip is spot on, a near perfect replica of the OEM grip. It would fit like a glove.
  11. Mapping the grip. It’ll be a whole lot easier for anyone trying to replicate my effort (albeit, successfully), if you know what you’re cutting into. I mentioned the “U” notch on the end, where the heating element solid wire wraps around to return (see photo, first post). Then there are the plastic “bumps” which the stranded wires pass through near the inside of the grip. The entire assembly is fastened to the bike’s handle bar via a T45 screw, which has a nut at the end. (If I recall, the screw runs horizontally, from back to front, with the nut being on the front side, and screw head in back.) The screw hole in the plastic handle is your reference point, to find the two notches where the connector wires are embedded in the rubber near the inside, and the U shaped notch on the end. My advice would be to find the screw (yellow arrow), then start on the outside end of the grip, using a sharp probe find the U shaped notch. The only place where you can really cause damage is near the crimped wires on the inside of the grip, so you can safely cut and “skin” the handle from outside in. When you get nearer he inside, probe gently until you find those two notches, and then work carefully about an inch and a half either way to try remove the rubber without damaging the stranded connecting wire, the crip, or the heating element. When I had the cover removed top and sides, I removed that T45 screw and took the plastic grip/handle off the bike to complete the work. (See the section following on removing the handle.)
  12. Grip mapping (second version) - Referencing the top of the handlebar as "12 o'clock":
    1. 1 PM: An inch from the inside edge of the grip, to 1.5 inches from the inside of the wheel. Two wire crimps.
    2. 3 PM: Where the Torx screw enters the handlebar, about 1/2 inch from the inside edge of the grip, or one inch from the inside of the control wheel, you will find the two raised plastic nubs thru which the two connector wires travel. (You’ll find the nut for the screw buried under the grip at about 9 PM.)
    3. 5:30 PM: Up against, and under the inside raised edge of the rubber grip, is the place, marked by a hard plastic nub, through which the connector wires pass, on their way outside the grip to the plug.
  13. I recommend waiting to install the new rubber grip until after reinstalling the entire grip assembly, and it's fixed on the bike. I’ve heard of various ways to slide a rubber grip back on a handlebar (in this case, the plastic OEM heated grip). My preference would be to use WD40 to lubricate the grip, then slide the rubber grip over it. WD40 is a lightweight lubricant, and should be completely absorbed into the rubber with little trace after drying.
    BMW’s Shop Manual Directions (paraphrased), R&R left grip assembly.
  14. Peel back the rubber grip, at the point where the grip joins the “wonderwheel” tofind the T45 Torx screw and nut. Remove it, and the assembly, i.e. plastic grip, wonderwheel, and multi-function switch will both rotate around, and slide off the bars. The assembly must be removed as a unit, i.e. the grip, wheel, and multifunction switch, then disassembled, and after reassembly, installed the same way.
    Complete Assembly:
    Exposing T55 Nut, and the hole through the handle bar after removal.
  15. To remove the left handlebar grip and switch assembly, the wires for both the grip and switch must be unbundled (i.e. there’s a rubber tie between them and the clutch cable), and the handlebars turned left to create slack. Then slide the assembly off. Note: There’s a small plastic piece, i.e. a door or cover, on the bottom of controller switch near the wires that should be removed to free (or loosen) the wires from the switch, and enable detachment/disconnection of the switch and heated grip connectors. The two attachment points have a visible snap in front, and a piece of plastic that slides behind the snap. (It was tricky to remove.) The pictures below show the part in place, and a close up, of how the “fork” attaches.
  16. BMW'S CAUTION: *** DO NOT *** follow the wires into the multi-function controller switch , then proceed to remove the two top screws (i.e. vertical to the bar) connecting the top of the switch to the bottom of the controller, as these are permanently resin sealed. (However, if one ignores the manual, he CAN in fact, remove the two screws and break it apart. I have it on ....er... "good authority" that it's possible, but don't ask me how I know. 🙄😖). DON’T DO THIS!
  17. Instead, there's a plastic piece, i.e. “the retainer” in BMW’s jargon, at the back of the controller with a clips that can be depressed to release the switch from the wheel & grip subassembly. Also Included are two connector plugs, one for the switch and the other for the heated grip, which have their own clips. Disconnect those, too, and slide the switch and wheel apart. The first picture is from BMW’s shop manual, the second is my own, taken during reassembly, viewed from the opposite (i.e. grip) side as the shop picture. On my picture, the plastic clip is to the left, the controller connector is bottom center, and the heated grip connector is to the right.
  18. As previously referenced, the three T55 screws There are three screws (marked as part #1 in the parts image below) connecting the wheel to the grip. Remove them. One of the screws will allow the heated grip connector to detach and pass through the center of the grip, separating the wheel and grip. The grip can now be repaired or replaced.
  19. Reassemble the grip assembly, and reinstall the same way things came apart.​
* MAX BMW
"Oops"
Update to follow.
You are a GOD among men, for tackling this project and reporting your hand grip findings after this expert dissection ! I hope you did not lose any sleep over this intervention, best part, add alcohol and have a friend read it to you! Thank you Jim on Long Island
Well, whether that was sarcasm or a compliment, I guess I deserve it. I feel more like a fool than a god for digging into it, in the first place. 😏 (And yes, generous alcohol was used in the final resolution.)
I saw this thread in a search, and scanned through what I had written. I mentioned above that I had found a OEM left grip for quite a bit less than USA retail in the UK. To make it clear, I eventually tossed my "project" grip, bought the OEM, and installed it. The right side grip is even more expensive. ~~ IF ~~, I replace that, I'll likely do it next winter, and yes, I'll try to use what I learned to replace the rubber cover on the OEM grip assembly, too, because the throttle side is about 3x more expensive than the clutch side. (I just won't spend quite as much time. If I can't get it done in a day, the order for the new one goes out. I figure I'll save a bundle on alcohol and healthcare if I just buy he OEM product. But, where's the fun in that?) 🙃😁
FYI.
