Gas cap has still not arrived. Was scheduled to arrive Wednesday but still not here today. USPS tracking says it will arrive late and is on the way to the next facility. .
Supposed to be delivered today, but I’ve heard that before. 13 days in the mail.
It arrived, it is installed and fits well. I had to remove more plastic than the fuel tank center piece. A significant piece of plastic is not used with the new fuel cap. The plastic houses the electrics, the connectors for the overflow and vapor capture hoses, and the funnel like piece that protrudes into the tank. To reach the electrical connector I had to remove the left side panel that goes forward and becomes part of the beak. Here is a picture after install, more pictures to follow when I am released from grandchildren herding duty.
Looking at the bottom of the fuel cap assembly; I do not understand why they made this fuel cap with the towers that form holes for the screws. Had they made the bottom of the gas cap flat like the OE gas cap, then the plasitic assembly could remain and the OE overflow, vapor capture and expansion tubing could be retained. Looks like it would be an easy job for a mill to remove them.
Looks great for sure!
My only issue will be I will need to hold or set a gas cap someplace when I fill. I can get over that I think.
It looks really good though.
I think that's only a GS thing. The R and RS does not have it and I'm guessing the same for the RT.akbeemer said:Also notice the two captured nuts on the assembly. Those are for two fasteners that are inside the small storage area in the center panel of the fuel tank cover. There is now no place to fasten those screws; it does not seem to cause any looseness in the panel.
Is there multiple applications for the cap?
