Boxflyer
Active member
A week ago while riding with a buddy that owns a 2014 R1200GS, we had parked for the night and I happened to notice that the rubber boot between the Final Drive and the Paralever was not completely seated at the top where it joins the Paralever.
Later in the week, I was doing a 12k service on this bike, so I could address the final drive boot sealing issue.
What I discovered was that because the front/top of the boot clips were not properly engaged, the accordion pleats on the boot had been worn thru due to contact with the U-joint yoke on the driveshaft.
So, because the front of the boot had been displaced rearward, the collapsed boot was ruined and was also letting in water/debris while riding in addition to the poor seal at the front.
I have a couple of extra final drives, complete with paralevers, for the WetHead and was able to cannibalize a rubber boot from one of those to complete the 12k service.
This is the part number for the replacement final drive rear rubber boot. 33357708117 https://parts.maxbmw.com/p/BMW__/Rubber-boot/46939180/33357708117.html
And as we all know, posts without pictures are incomplete...
Rubber boot in its normal/resting position. Angle is about 45deg, and folds on the boot clear the rear U-joint yoke
Rubber boot in approximate position if the front/top clips and seal are not properly seated in the Paralever
Here I'm trying to show how the inside of the folds of the rubber boot are compressed when the front of the boot is pushed reward.
This is the hole worn in the rubber boot after contact with the rear yoke on the U-joint.
Just another point of reference to pay attention to when performing routine maintenance on these bikes.
Hope this helps someone.
