D
D-Mac
Hi all,
I'm back home from the 2011 Iron Butt Rally. While I'm happy that I finished, and pleased overall with the RT, my bike wasn't entirely problem-free.
It started at the start line with a failed stepper motor (happened during my 12,000 mile service appointment, which I did at 11,500 miles). The bike wouldn't idle properly. Dealer was up much of the night getting it fixed. After the motor was replaced it ran ok, although it does stall once in a while when first fired up (it did something similar when new).
As I arrived at the finish line (about 9000 miles later) I discovered that my final drive was leaking (!) It looked like the seal had failed, so I took it to a local dealer (in LA). They confirmed the seal failure and replaced it (along with the fluid of course). They told me I probably would have lost the final drive within another 50 miles. I then rode 1000 miles over the following two days and discovered the new seal leaking again (just inside Utah it started spewing out lots of oil in a motel parking lot). I had the bike towed to Salt Lake and waited 1 1/2 days for the dealership to open. They said it was just another seal, but that it seemed like a little more oil than normal came out when they drained the final drive (so perhaps it was overfilled, causing the second failure). New seal #2 was installed. By this point you could see a lot of marring around the hub from prying off the plastic ring....
About 1700 miles later I arrived home. The bike has about 23,000 miles on it now and it's about 10 months old. I hear they added a vent on the 2011s to keep pressure from causing a seal failure. My riding buddy who has a 2009 GSA he bought new a year ago has nearly 60,000 miles on it has never had a seal fail, although he's seen three failures on other bikes this year and he just ordered the seal driver from BMW for his tool kit. It looks like seal replacement could be done on the road without much trouble. Anyone ever do this?
I also had some electrical issues during the rally. Canbus now shuts off power to my GPS accessory port at regular intervals (generally about 5-15 minutes after the bike is on). My rear accessory port has also stopped working. I have been using the BMW GPS plug for switched power to my fuseblock, but it looks like I'll be tapping the park lights instead. I'm also going to convert the accessory plugs to draw power from my fuseblock and bypass the bike.
