Any suggestions welcome.
I torqued the FD plugs to 32 instead of 23Nm. Oops. I loosened them and torqued them to 23Nm. I wonder if I need to replace the aluminum washers. I have an extra set.
FD oil was a bit low when started. Visible but not at the top of the filler drain. I didn't find much other than metal fuzz on drain plug. Oil dirtier than I expected. Picture below.
Washers purchased from Boneyard. Nice company. Oil from the auto store. I listened (possibly too much) about using synthetic 70-140 gear oil and it impacting seals. Personally I prefer the synthetic stuff but I used the 80-90w gear oil for now. Nice to have a base line on maintenance. Let me know if I picked wrong for Midwest climate, under 1500 miles per year usage.
I have these specs for the 2003 K1200GT:
Final Drive filler plug 6mm hex Allen torqued 23 Nm aluminum seal ring I have seen specs as no ring seal though. Mine had a ring on it from BMW dealer
Final Drive drain plug 19mm nut socket torqued 23Nm aluminum seal ring
I had to wait on the transmission change. Was next to do this evening, but I couldn't find a 14mm Allen bit socket in my tool box. 10mm the highest. Hey, maybe in the BMW tool kit...nope. HomeDepo..nope, Lowes..nope...Sears Hardware...nope. Ebay, yep.
Transmission filler plug 8mm Allen seal ring torque at 23 Nm
Transmission drain plug 14 mm Allen no seal ring 55 Nm. Multiple bog and YouTube videos reference this at 55Nm. Seems too high.
Thanks for your suggestions.
