Well, I hope you all know that if counter steering doesn't work for you, you will have to "lay 'er down" sooner or later.
Let me put it another way. Motorcycles maintain or change their direction of travel based on complex physics. They are immune to the personal desires or idiology of the operator. They will only turn precisely if they are given input inline with the physics that govern them. If you think you are "heaving" your bike then you are simply unaware of how you are actually providing input to the motorcycle. I used to beleive the "lean to turn" mantra. My wake up call came as l was leaning into a left hand turn and travelling in a straight line heading towards a mailbox. I managed to stop before striking the mailbox. It was then l began to open my mind about motorcycle handling. If you are making turns on a motorcyle you ARE countersteering, it's how motorcycles turn, it's not something you can choose to do or not do.
To quote the spokesman for a past Governor of Alabama who was explaining the Gov's wrecking his HD on the Dalton Hwy, (the spokesman described the Gov's actions as heroic), "He had to lay the bike down to avoid an accident."
Trouble is, in order to "lay 'er down", you pretty much have to counter steer.
At very low speeds the physics involved are not quite the same and direct steering is called for. Lee Parks explains this very well but l am a little fuzzy on the scientific explanation so I will not attempt to describe it.
I think the real problem with counter steering is trying to conceptually understand the physics and why it works, not the fact that it does work. The "counter" in counter steering is that it is counter intuitive so that it appears to logically go against what one expects and that causes the unending discussion of the topic.
Actually, you kind of did. Counter-steering is simply a slight maneuver to redirect inertia towards the direction you wish to turn.
With no momentum present while stopped, the maneuver is both different and more relaxed.
Just ride - physics will sort itself out quite well without all the handwringing.
