Cardo PackTalk Bold Review - Not a favorable opinion
I was using Sena SMH10's for the past 6 years or so and was fairly happy with them but was spending more time with a pillion and wanted to be able to have an open intercom while sharing music which the Sena did not do. I had also recently added a Garmin to the mix and found it interrupted our Intercom conversation. After doing extensive research I found the Packtalk bold would do all of these, or so Cardo says in the advertising. The Packtalk Bold is a very nice system for groups of riders, without Pillions. When adding a pillion the system fails completely.
- The system is supposed to share music while intercom is active and available in DMC mode. This was done as an update so it is not in the manual however Cardo has a video on it. This does not work because of back ground noise activating the intercom which cuts the sound level of music and adds some not nice crackling noises. Cardo support has been of no help with this issue, they stated to set background music to 100% via the app which was already done on both units. Mic Sensitivity is also set to the lowest setting and we have tried both "intelligent" noise cancelling on and off, its better with is on. I have ordered some larger wind socks from Cardo but have not had a chance to try them yet. But they do look and taste awful as they are so large one cannot get them away from the face inside the helmets. I think the issue with this is how quiet our helmets are so the slightest exterior sound or wind noise activates the intercom. We are using the Schuberth C3 Pro and AGV Carbon along with being behind a Quiet ride screen on R1200RT so its pretty quiet which seems so confuse the Cardo Units. I think if there was constant background noise the system would be less inclined to think we were trying to talk every time it hears a little noise. You can share music while in Bluetooth mode instead of DMC however not while intercom is open.
- The GPS always interrupts intercom. The manual and app say you can set priorities so that the intercom will be higher than the GPS this is completely untrue and has been stated by Cardo tech support to be untrue. GPS is always the 1st priority and cannot be heard at same time as any other inputs, this is regardless of pairing as GPS or just another Bluetooth device. This would not be so bad if the Pillion knew no one was listening to them or if the system didn't take so long to go back to intercom but there is a good 4 seconds of silence between spoken directions from GPS and reactivation of the intercom. The system also beeps when reconnecting, this would be great if it did it when interrupting but doing it upon reconnecting is useless if passenger had no idea they had been muted.
- When reading up on this system it sounded like it was capable of having intercom open while sharing music and being able to have GPS not interrupt but give directions at the same time with channel open to all three inputs (Bluetooth mixing). It does not do that.
I have been disconnecting the Garmin Bluetooth when a have a passenger and relying on visual which of course is dangerous to look at thee GPS while underway so as not to be completely frustrated every time the Garmin tells me 4 times to take the next right or my favorite continue on route interrupting conversation and music and beeping away. I wouldn't think that emulating being in a car having music playing while talking while GPS is announcing directions would be all that hard.
In the end I have spent $423.99 for the same exact system I already had that was paid for years ago, albeit with better bass and sound quality, due to the amount of time it took to try these systems tried out and get in touch with Cardo Tech support the return window has long since passed. I am writing this to help prevent others from falling for the same false advertising as I did. It is a very nice system and has very good sound quality however not nearly worth the $$ it touted a lot of claims that it simply is not capable of and what it does do it does not do well. If you want a system to ride in a group without a pillion this is great however if you have a passenger keep looking.
After spending an additional $27.00 for shipping, Cardo sent replacements, these I was able to share music with a old Android however not a newer model or Iphone XS or Garmin 595 at that point I gave up and returned to retailer, I would stay away from the Cardo lineup if trying to do more than just integrate with a phone or talk over intercom, none of the other features work or if they do they do not work well. Cardo tech support is awful they never answer the phone and take days to answer an email with little to no substance, all of their responses can be found in the manual.
