Timing Chain
I haven't posted in awhile, but the rebuild on this R100RS has been creeping along. I do believe that I have accumulated every part, gasket, seal, bearing and everything else that I could possibly need.
I just pulled the crank bearing last night, and now I need to pull the chain. I have new chain, crank and cam sprockets. Someone had recommended grinding off a link to remove the chain. Yea, that is possible, but I don't think I can cover the engine enough to avoid the ground metal flying about.
Has anyone used bolt cutters on this? How did it work out?
