olironrider
Active member
… keep thinking about your left cylinder head problem ?
Any thought about breaking down the ‘70 head’s exhaust valve to check spring height, upper/lower washers, keepers and, valve stem diameter, face, seat ?
How about the height of the pressed-in “spools” that support the rocker pivot blocks, above the face of the cover gasket surface ? If feeling “adventurous”, same look-see on the spare ‘71 head ?
Figure you already checked to see that “OT” of the flywheel agrees with TDC of piston.
comparison ?
If you rotate one revolution from both valve closed on TDC, do both valve show slight movement, i.e. exhaust opening and intake opening together… the cylinder is setting-up for the next fuel/air charge ?
Kind of like a “dog with a bone” here, every spare moment I’m thinking about this !
