AnnapolisAirhead
--Tony
For some reason, I can't get my transmission into 1st gear anymore.
So, I figured the clutch cable was old and perhaps near the end of its useful life. Last night, I replaced the clutch cable, using Tom Cutter's cable install and adjustment instructions and all other gears work fine (smooth actually) and pull hard. Since he was a trained BMW tech in the day, his instructions have always provided sage advice. Downshifting hasn't been an issue either--which I'd heard was an indication that the splines may be bad.
After looking into the shifter linkage last night more, it seems like it can't actually move the small lever of the linkage far enough forward to engage 1st gear. Although, if I shift to second or highter, everything works as it should.
The only time if seems I can get it into 1st (sometimes) as I am rolling to a stop. This is a new issue and a puzzling one as I ride it almost daily to and from work without any issues. The only thing I did to the bike was replace the diode board, rotor, alternator brushes and voltage regulator--so, um...er...
Any ideas?
Any ideas?
