1150 gs mounting kit???
Davesbmw
I have a sidecar off a 1983 r 80 airhead and would like to mount it on my 2000 1150 gs.
Doe anyone know where to find info on mounting kits or how to mount a hack on a 1150 gs?
You might try DMC Sidecars. I know that to start with, you'll need a subframe on your GS to give you something to attach the sidecar to. I'm sure there are other sources but this may be a good starting point. What kind of sidecar do you have? Ride easy and good luck,
gp
gp
the label on the side says cnymhuk bm3 ? russian? ural?
the tub is steel but does not look like your typical Ural hack
