EMOTO
Active member
Nobody here said he was bad.
Yes, I know. I just wanted to make a positive statement because I like the guy. It was not a counter to anything at all.
I thought you were taking a shot my recommendations. No worries!
Of course nobody likes to let out proprietary secrets......The reading reminds me a lot of Soda Blasting.
SB is one of the new ways of cleaning material with minimal damage to the base material. I guess the next level up is walnut shells.
It would be nice to get an engine spiffed up without disassembly.
I tried for about 2 weeks solid to find and buy that Facto stuff from a US distributor, finally did get a (frankly ridiculous) price for the stuff, so I'm not pursuing that at the moment.
...but the clear anodize is interesting to me. One point about that though - I asked my plater about it and he said that the parts cannot have any ferrous metals pressed into them when this is done. Said they'd turn to goo more or less.
One of the guys on the Porsche forum who lives in Chicago was able to get a pail, but it took some doing. The US distributor had a tough time shipping it and now shipping a pail seems to be rocket science for some reason.
I can get a pail of Facto AT30 locally but they price it too high up here so I pick up a pail or two when I am at their facility in the US.
Could be. If the metal part is available separately or can be pulled without damage, I'd simply replace it into the casting after the anodizing process.
BTW, I just got myself a nice Skat Blast 960 Pro Blaster Abrasive Blasting Cabinet. More than good enough for home use.
You absolutely need a dryer for your air supply - do you have one?
N.
My Brother has one at his shop. When he bought his, he found the lighting inadequate so he added his own light.
Yes, but only the pellet type. If I have problems, I'll go all out and get an AC drier.
This blaster will be in the basement where my large compressor is. The air is pretty dry down there, especially in the winter.
A friend lent me his small table top blaster last summer and I used my 2 HP compressor to run it. Even in the hot humid summer, I had no clogging issue at all.
My Brother has one at his shop. When he bought his, he found the lighting inadequate so he added his own light. He also takes the window out and lines in with a quality plastic food wrap to protect the window- changing it as needed.
It's a great prep tool.
I just received a 20-pack of acetate sheets with two-sided tape around the perimeter, about 2 bucks each. Those things fog up quickly. I never would have thought to try cling film, and I have a nice 20 inch roll of the stuff. I may try a few wraps of that next and use it like tear-offs
N.
Gary's post got me looking: http://www.garagenight.tv/diy-soda-blasting-build-your-own-rig-cheap/
